Home > Puma (Tdci) > Hard top bottom seals 90
hjellemorten
Norway 2007 Defender 90 Puma 2.4 HT Rimini Red
Have lifted off the hard top and plan to replace the seals. However, slightly confused as I can only identify item 3 on the drawing below. Anyone who have a photo of where item 6 and 7 is located?
Item 3
RH lower AML710060
LH lower AML710070
Item 6
RH lower LR020356, replaced by LR079820
LH lower LR020357, replaced by LR079823
Item 7
RH lower, corner LR020352, replaced by LR079190
LH lower, corner LR020353, replaced by LR079191
Post #997386 24th Jun 2023 4:51pm
NickMc
Depends on year, if yours is a puma they tend to just have the one piece foam seal part no 3, it’s not a very good representation of it on the diagram.
This is what they look like
https://yrmit.co.uk/product/side-panel-to-...fender-90/
Post #997393 24th Jun 2023 5:36pm
hjellemorten
Alright, it is a Puma 2007. The previous owner have used additional silicone. With only the item 3 “foam” seal, I would expect water to find places to sit over time and create 🤕 . Luckily this has not happened in my case.
Would it be recommended to apply a silicone joint all the way around between the lower and upper body?
Post #997395 24th Jun 2023 5:43pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
I bought the YRM seal for item 3, serious job
Post #997528 26th Jun 2023 8:54am
hjellemorten
How is the YRM quality’s the genuine part?
Post #997535 26th Jun 2023 10:07am
