Home > Maintenance & Modifications > Coolant Leak…. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 900 |
Further photographs are required, from above and below, to have a go at saying where the coolant originated.
It could be a core plug, a leaking hose, a split heater matrix, or the water pump. Essentially, it’s impossible to say from just a pool underneath as fluids don’t always hit the ground directly below the point from which they leak. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
22nd Jun 2023 12:37pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5732 |
You sure it’s not condensation from A/C?
22nd Jun 2023 12:41pm |
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 |
Andy no it’s def red fluid cannot see anything visible from pipes etc
22nd Jun 2023 12:48pm |
Which engine do you have? What does the fluid feel like, is it oily or watery or sticky?
22nd Jun 2023 1:37pm |
It’s the 2.4 Puma, it’s watery issue is I can’t get in to have a look, will try later from getting under it to take a look.
Click image to enlarge |
22nd Jun 2023 1:42pm |
So being that it is watery and you have a RHD I am going to say something to do with the heater box, AC, hoses or matrix. Get up above the heater box with a decent pen torch and see if you can find the tracks of water. If there is nothing apparent externally then it might be more matrix/core related.
Do you have AC? |
22nd Jun 2023 1:52pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2430 |
Fuel cooler or oil cooler. Both easy to spot from underneath. Puma 110" SW
22nd Jun 2023 2:00pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2302 |
Check the heater valve. These can fail and leak > 110 XS Double Cab
22nd Jun 2023 4:04pm |
Ok will check all around tomorrow, yes it does has AC |
22nd Jun 2023 6:28pm |
