![]() | Home > Maintenance & Modifications > Coolant Leak…. |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 916 ![]() ![]() ![]() |
Further photographs are required, from above and below, to have a go at saying where the coolant originated.
It could be a core plug, a leaking hose, a split heater matrix, or the water pump. Essentially, it’s impossible to say from just a pool underneath as fluids don’t always hit the ground directly below the point from which they leak. Charlie 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5849 ![]() ![]() |
You sure it’s not condensation from A/C?
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 ![]() ![]() ![]() |
Andy no it’s def red fluid cannot see anything visible from pipes etc
Which engine do you have? What does the fluid feel like, is it oily or watery or sticky?
It’s the 2.4 Puma, it’s watery issue is I can’t get in to have a look, will try later from getting under it to take a look.
So being that it is watery and you have a RHD I am going to say something to do with the heater box, AC, hoses or matrix. Get up above the heater box with a decent pen torch and see if you can find the tracks of water. If there is nothing apparent externally then it might be more matrix/core related.
Do you have AC? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2462 ![]() ![]() ![]() |
Fuel cooler or oil cooler. Both easy to spot from underneath. Puma 110" SW
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2320 ![]() ![]() ![]() |
Check the heater valve. These can fail and leak > 110 XS Double Cab
Ok will check all around tomorrow, yes it does has AC |
