Home > General & Technical (L663) > Does the new Defender have a blind spot? |
TRGRichie Member Since: 03 Mar 2021 Location: Yorkshire Posts: 180 |
Sounds like he didn’t look at his blind spot indicators on the mirrors before manoeuvring L663 90ht
19th Dec 2021 4:26pm |
martinf Member Since: 30 Nov 2020 Location: Sussex Posts: 99 |
A slightly different issue but nevertheless related to visibility is the lack of visible lighting on the sides of the rear wings.
I was reversing out of a small drive onto a busy road and a driver coming along the road commented that I was almost invisible side on. Looking at other cars, rear lights typically wrap around the side to give side on visibility. Seems an odd design fault in 2021. Last edited by martinf on 20th Dec 2021 4:04pm. Edited 1 time in total |
19th Dec 2021 5:23pm |
Gareth Member Since: 12 Dec 2011 Location: Bramhall Posts: 1106 |
The only blind spot I notice is the one caused by the door mirrors. Combined with the thick A post, it’s quite a large area you can’t see. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy 1968 S2a 88 aka Bob 2014 Jaaaag F Type 3.0 Supercharged. |
19th Dec 2021 7:29pm |
J77 Member Since: 04 Nov 2019 Location: Fife Posts: 3404 |
Can’t say I’ve had much issues with blind spots, the B-pillars are quite thick. Overall visibility seems pretty decent. 24MY 90 D250 HSE, Tasman Blue
19th Dec 2021 7:51pm |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2661 |
Isn't it against the highway code to reverse onto a road? 110 D250 SE HT 110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
21st Dec 2021 12:24pm |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 531 |
Think its only A roads and above, not that that stops people....
21st Dec 2021 12:52pm |
Rule 201 says "When using a driveway, reverse in and drive out if you can."
21st Dec 2021 4:10pm |
dshark1 Member Since: 17 Jun 2023 Location: Florida Posts: 20 |
Just got my defender, only complaint I have with the Blindspot monitoring is the lack of no sound to alert the driver of another vehicle. Only lights
17th Jun 2023 3:33am |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3677 |
Blind spot on the 90HT (and I guess 110HT) is huge. Blind spot indicators are a good send. Do you know whether it was a HT.
17th Jun 2023 7:10am |
Nuclear Nick Member Since: 21 Aug 2021 Location: Southwest Posts: 284 |
If you leave Blind Spot Assist on you will get a steering correction and audible alert if you attempt a lane change with another vehicle in the blind spot monitoring area. On UK motorways if there was an audible alert with blind spot monitoring it would be sounding off continuously! |
17th Jun 2023 7:56am |
Yes, I am just use to getting audible sound when u turn on signal prior to lane change, if there is a vehicle on your side. It seems here that u have to actually engage in the lane change prior… is this correct? |
17th Jun 2023 1:17pm |
I am use to getting the audible signal once u turn on signal light if there is another vehicle. But I do understand what you are saying. Thx for that. |
17th Jun 2023 1:20pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1763 |
Ever since I first saw the pre production Defender I thought the rear lights were a safety concern for two reasons. The recess design holds dirt and snow that doesn't melt because LEDs don't produce heat and secondly they don't wrap around the body to give any light output to side of vehicle. I think all Defenders should have the US style side markers for this reason.
18th Jun 2023 8:06am |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2832 |
l've got a 90 HT and have had no issues with "blind spots" However l drove a van for 14 years so am used to vehicles of this type.
You just have to take more care when driving it. |
18th Jun 2023 6:18pm |
