![]() | Home > Technical > Unidentified unused connectors behind headlight? |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
![]() Click image to enlarge Left to right, optional extra horn for alarm, battery backed-up alarm sounder and headlight levelling. Steve 02' 110 TD5 Double Cab Rebuild Thread |
murph81 Member Since: 11 Sep 2022 Location: Ireland Posts: 63 ![]() ![]() ![]() |
Great stuff, thanks Steve!
tommac Member Since: 03 Jul 2018 Location: devon Posts: 26 ![]() ![]() ![]() |
Great stuff Steve- you’ve solved a query I had- I have 2 of these floating around behind the headlight- couldn’t work out what they were for! How many defenders have levelling headlights!?
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Loads, any with XS spec probably will.
Ah- fair!
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 ![]() ![]() |
LR Workshop has a good electrics section, including a “connector by wire colour” which has helped me identify unused connectors no end of times
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 853 ![]() ![]() ![]() |
I believe that headlight levelling came standard on County Station Wagons after 1997?
Jim |
Quite likely, although not fitted to County-spec variants of "commercial" models.such as the DC, which "benefitted" from the hopeless and stupid dim-dip system.
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1147 ![]() ![]() ![]() |
I had a 1999 CSW which did not have it.
I have had (different) cars with and without and can't see it's all that valuable. I think I had a D2 which had adjustable headlights AND rear air suspension, I mean, really....? With modern lighting as it is, most people have accepted that occasionally you will be completely blinded by oncoming traffic. |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2194 ![]() ![]() ![]() |
Far worse and dangerous now that we seem to have entered the twilight zone in terms of modern vehicle lighting......
Why should it simply be accepted?? |
Thanks @the lincs Landy- will take a look!
