![]() | Home > Maintenance & Modifications > Extensive corrosion on LED Spot Lights |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17679 ![]() ![]() ![]() |
Sadly typical of modern, poorly-applied powder coat. All you can do really is replace them or clean them properly back to bare metal,.etch prime and paint.
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2128 ![]() ![]() ![]() |
Yes I agree. Probably poor prep. Happened to my driving and work lights.
I stripped, etch primed and painted. They look okay but are already starting to peel/flake in some areas ☹️ |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3393 ![]() ![]() |
They're only a few quid on ebay now to replace.
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
This stuff is good as part of the prep:
https://raceglaze.co.uk/shop/race-glaze-ca...ser-500ml/ Also handy around the house for limescale removal... |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 861 ![]() ![]() |
Sadly that looks to be the result of cheap crap (even if they charge you a lot to buy them).
Aluminium would likely be better served being anodised as opposed to powder coated. |
For £7 delivered, what to you expect?
![]() Click image to enlarge ![]() |
the_lincs_landies Member Since: 29 May 2023 Location: Boston, Lincs Posts: 230 ![]() ![]() |
Look just like the rear worklights on my 110 did when I bought it. Ended up replacing for Auxbeam 5" Side shooters. Everyone raves about the auxbeam switch panels so I am hoping the lights are equally as good...
pjh Member Since: 23 Nov 2010 Location: West Yorkshire Posts: 126 ![]() ![]() ![]() |
I'd not come across that before, thanks for the recommendation. Defender 11MY USW |
