![]() | Home > Td5 > Td5 engine readings |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
I haven’t, but have a Td5 and a nanocom, so if you list what you want/have I could plug mine in a give you my results/readings.
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
I have note in the case for the Nanocom. 55-61 at idle is what I have noted as being good and should increase with revs. 1999 Defender TD5 110
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 563 ![]() ![]() ![]() |
Isn't the injector balance at idle meant to be +/- 5 ?
Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 968 ![]() ![]() ![]() |
This would be a great list of normal values to have as a sticky for the group!
![]() 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
ajps72 Member Since: 08 Jan 2012 Location: Lima Peru Posts: 105 ![]() ![]() |
I have +- 2, on a TD5 repaired 10 000 km ago Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
I have recorded some readings on my defender. at sea level climbing a small slope.
MEASURE 1 AT 90 kmh, 2389rpm, acc track 1 3243 MAF 348 Turbo 177.6 Air inlet temp 39C Coolant temp 83C Fuel temp 65.4C EGR Inlet 26 (but is blank anyway) cyl +2 to -5, but is not a good reference with an accelerating engine, should be compared at idle. MEASURE 2 AT 90 kmh, 2375rpm, acc track 1 565 MAF 212 Turbo 110.5 Air inlet temp 41C Coolant temp 85C Fuel temp 65.4C EGR Inlet 0(but is blank anyway) cyl +3 to -4 Augusto Defender 110 TD5 2001 Discovery 4 TDV6 |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
Great stuff, thanks guys
