Home > Puma (Tdci) > Slow Clutch? (with Poll!) |
Kevlar Member Since: 28 Oct 2020 Location: Prague Posts: 78 |
I installed the spacers under the gear shifter, didn’t help too much.
I plan to replace my clutch soon, hopefully it will solve the gear changing issues. Currently I have to double clutch sometimes or blip it into gears. |
31st May 2023 6:34pm |
pedrocandrade Member Since: 30 Sep 2022 Location: Rio de Janeiro Posts: 26 |
Thanks Kevlar. I added a poll to this topic to try to grasp how common this issue is. Is it a feature (part of the Puma charm) or a real bug that we might be able to fix?
31st May 2023 9:12pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
Double-declutch up and down and don't rush the changes.
31st May 2023 9:14pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2100 |
Changes on my Puma 2.2 are smooth from 1 to 6 and back down again.
As per your other post on whine from gearbox / transfer box https://www.defender2.net/forum/topic85095.html When you had the gearbox out did you check your clutch springs ? They fracture, especially on the earlier Puma’s and can cause all manor of issues. |
31st May 2023 9:35pm |
Thanks blackwolf and Ianh.
Double clutching might help going to 2nd, I’ll try. But the biggest annoyance is going to 1st at a stop sign. I didn’t check the clutch when servicing the gearbox and transfer case but thanks for the tip about the springs. My Puma is a 2011, was that year still problematic? I saw in its service history that the clutch was replaced at the dealer with 60.000km on the clock in 2016. There were noises being heard from the clutch while idling, apparently. It now has only 100.000 km. This car was not driven hard, I believe. Appears too early to be needing clutch service! |
1st Jun 2023 12:47am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3650 |
when mine was new 1 to 2 was rubbish the rest were OK, new clutch, ashcroft output shaft, bushes in the gear change, ashcroft ATB diffs, and one piece rear half shaft and now its actually lovely in all changes. DEFENDER 90 TDCI XS,
1st Jun 2023 5:27am |
Thanks, LR90XS2011! It’s good to know that you were able to solve it without messing with the gearbox itself.
1st Jun 2023 12:33pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
The gear change on my 2015 Puma was notchy until I changed the gearbox oil. That improved the changes considerably. It can still be a bit notchy when cold but OK once warmed up.
In general I find that when changing gear a slight pause in neutral helps a lot. There's a lot of stuff spinning down there. It's a long way from the rifle bolt action of my old Lotus. |
1st Jun 2023 2:39pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2445 |
Are you using the right oil?
The previous oil I was using was better than the current oil. Now, going from neutral to 1st is a bit more difficult. The rest of the gears are smooth. Puma 110" SW ............................................................. Earth first. Other planets later |
1st Jun 2023 3:40pm |
Overfilling the box can also cause an effect like this and, since there is no level plug, is quite common.
1st Jun 2023 4:38pm |
Thanks steveww, MK and blackwolf. All good tips that I’ll look into. We replaced the gearbox oil during the transfer case saga. I’m pretty sure it’s the correct one, but I’ll double check. It could be overfilled as well.
BTW, the gearbox does get better as it warms up, but it turns out my city drives are too short for that. I’ll look into this over the next weeks and report back on the findings. |
2nd Jun 2023 12:04am |
Landowner Member Since: 06 Jan 2023 Location: Somerset Posts: 76 |
pedrocandrade, keep us posted, currently 33% of your survey could benefit from what you discover!
For my part, new oil (and correct amount) soon! |
2nd Jun 2023 5:57am |
A defective spigot bearing can also cause similar symptoms.
2nd Jun 2023 7:40am |
I found out the oil I'm currently using in the gearbox. It's this:
Click image to enlarge Full specs here: https://totalenergies.com.au/system/files/...109_en.pdf Is this ok? |
2nd Jun 2023 2:26pm |
