Foxwing on SD Cage
Anyone mounted a foxwing or similar to a SD external cage? Looking for ideas please. I am expecting to do some fabrication but I need to be able to remove it.
It is not going to help you but I have my awning fixed to the underneath of the SD roof rack. Works a treat as it pushes the awning out enough to clear the curve of the roof.
If I were fixing to the tubes of the cage I would use the SD clamps as they really fix well to the tubes, whereas the roof tent ones are not designed to cope with something hanging off them. I would be concerned they would slip on the tubes.
Sorted now.
I picked up a JB roof tent (Facebook bargain, 700 notes and unused) so decided to work out something to mount them both on.
Used the SD clamps I had lying around (can't even remember where they came from), a recycled set of Van Guard roof bars, a commercial chopping board and a handful of stainless fasteners.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
