Home > Maintenance & Modifications > Foxwing on SD Cage |
bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 920 |
Anyone mounted a foxwing or similar to a SD external cage? Looking for ideas please. I am expecting to do some fabrication but I need to be able to remove it.
Current thinking is to make use of the roof tent clamps I have lying around : https://shop.safetydevices.com/products/ro...ed-thread. Thanks |
2nd May 2023 9:55pm |
It is not going to help you but I have my awning fixed to the underneath of the SD roof rack. Works a treat as it pushes the awning out enough to clear the curve of the roof.
If I were fixing to the tubes of the cage I would use the SD clamps as they really fix well to the tubes, whereas the roof tent ones are not designed to cope with something hanging off them. I would be concerned they would slip on the tubes. https://shop.safetydevices.com/collections...ount-clamp More expensive but solid. |
3rd May 2023 11:57am |
