Home > Technical > Injector Cleaning and Oil Spec
Gabriel Boff
Brazil 2009 Defender 90 Puma 2.4 XS CSW Tonga Green
Hi! I'm from south Brazil
(sorry for the bad english)
Well, I recently bought a new LR Defender 90 CSW PUMA 2.4.
In the first 10000km maintence (here is in 10000 km because of the poor quality diesel, lot of sulfur)
the mechanics use a STP fuel sistem cleaner, for diesel sistems, in the Europe, you also do it?
And, what type of motor oil you use for the new Puma 2.4?
Here we use the Motul 8100 - 5w30 fully sintetic
Post #9930 20th Apr 2009 2:04am
MK
You should use a semisynthetic oil meeting LR specs Puma 110" SW
Post #9954 20th Apr 2009 11:27am
Gabriel Boff
You know what oil do you use?
What "label"?
This Motul meet the LR spec.
Post #9958 20th Apr 2009 6:03pm
Gabriel Boff
Complementing:
This Motul, here in Brazil is used in all LR diesel models (Range, Disco3 and New 2.4 Defenders)
And acording LR Mechanics is, better than the original recomended.
(I thik thats really better, If you look the price is a lot much better!!!!!!!!!!)
Post #9959 20th Apr 2009 6:05pm
MK
Ditec, our local stealer uses Mobil 1 "approved "by Brazil. And also the technicians say it is a lot better than the LR spec (Ford WSS-M2C913-B).......b**l sh**t.
You can probably get YPF Fuel Economy 5W/30. I would stick with this one unless LR states otherwise. Puma 110" SW
Post #9961 20th Apr 2009 7:03pm
Eduardo
Hi Gabriel,
Motul 8100 5W-30 appears to comply with STANDARDS ACEA A5 / B5 and APPROVALS API SL / CF
But not with the WSS-M2C913-B or WSS-M2C921-A (High sulphur content diesel) as stated in the maintenance manual.
Accordingly, a Motul SPECIFIC FORD 913B 5W30 should be used (if you like to stick with Motul).
Cheers Eduardo
Post #9963 20th Apr 2009 7:14pm
Gabriel Boff
You two are right.
When i look for the correct oil, i found the Motul SPECIFIC FORD 913B 5W30, in the first inspection, in my dealer they show me an bottle of Motul 8100, which I looked at, and realise that isn't meet whith LR Spec.
But, lets see ehat happens, like I said they use this motul 8100, in all LR diesel models here.
The Castrol TXT Softec Plus A1 (which meet the LR spec), is the original oil used by LR???
Thanks a lot for the information
Post #9977 20th Apr 2009 9:04pm
Eduardo
Gabriel,
Check the fuel consumption.
When I used Mobil 1 (dealers put it) my consumption increased from more than 9 km/lt to 8 km/lt.
That was one of the main reasons to do not accept again other that the specified oil. Currently I use Liquimoly Leichlauf Special (5W 30)- Quite expensive compared with others but I paid it with the low fuel consumption.
LR manual does not indicates any specific supplier for motor oil.
Cheers! Eduardo
Post #9978 20th Apr 2009 9:14pm
MK
Probably the factory fill is Castrol Magnatec 5w/30.
YPF is a lot cheaper and meets LR (Ford) specs.
http://www.castrol.com/castrol/sectiongene...Id=7048319 Puma 110" SW
Post #9979 20th Apr 2009 9:25pm
