Home > Td5 > earth grounding points in engine bay
Page 2 of 2 <12
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
coln18 wrote:
getting conflicting advice on this one, on landyzone they are telling me any bolt in the bodywork will do, as 50amp is nothing for a current running through the size of bodywork on a landy, yet on here everyone is telling me to find a proper earth grounding point as 50 amps is a lot....mmmm could be a toss of a coin one this Whistle
It's not so much what it's earthed to, it's more the earthing point itself. It's all very well connecting it to the bodywork but if you do it through a paperclip you are soon going to start frying things Rolling Eyes
Just think about the smallest cross-sectional area that the current is having to travel through. This will almost certainly be at the connection point. Big bolt = ok. Small twiddly bullet connector/rusty things = not ok.
Post #99226 10th Nov 2011 8:46pm
K9F
Rolling with laughter
Yeah! My dick's a kipper! And.... the cheque's in the post! Phillistines that's what they are! Laughing
For goodness sake let's lay this to rest! Are you sitting comfortably? O.K. let's begin.....
Power = Voltage X Current
Therefore the total power rating for your Heatshot ignoring 'Diversity' (too complicated and too tanked to explain! 'PM' me or Google it if you want to know what 'Diversity' is. On reflection don't 'pm' as I probably won't get back before 2015) and the characteristics of any thermostat it may have is...... let me think....one ale too many as I'm in drydock in Portsmouth and been on the lash....
Power = 12 X 50 which is 'erm......Oh I know (hand up! Laughing ) 600Watts.
Without a good earth you could potentially generate in layman's terms nearly the equivalent of 2/3 of a single bar fire of heat at the poor earth connection. As stated do not just 'nail it on' anywhere. If you offroad even your engine earth cannot be deemed as being a good earth. Check it first! Thumbs Up Hopefully there is no ambiguity or doubt in my retort!
Thumbs Up
As a footnote when fitting my subwoofer what I 'presumed' to be a good earth was not! My presumption was based on the fact I was a sparky and knew a good earth when I saw one! I was wrong and should have 'belled it out' (checked it with a meter first!). Even pros make mistakes! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #99286 10th Nov 2011 11:18pm
coln18
Thumbs Up
Cheers for that mate, i shall make sure its connected to a good earth grounding point.
Hope your hangover aint too bad in the morning Thumbs Up
Post #99296 11th Nov 2011 12:31am
K9F
coln18 wrote:
Cheers for that mate, i shall make sure its connected to a good earth grounding point. Hope your hangover aint too bad in the morning Thumbs Up
Off Topic Thank you! Was a little delicate this morning and learnt another BIG lesson in life! In dry dock you have to go shoreside to poo and it can be quite a long way to go! Do NOT leave it until the last minute to go....get all the way to the pot and find there's no poo roll! (Thought at one stage I was going to fill my boilersuit!)
Mental note made.....Take a roll with you next time and every time you go to poo! Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #99411 11th Nov 2011 7:27pm
Lorryman100
Mal, you don't need to carry a loo roll about with you all day as you only really need one piece of loo paper, simply take one sheet of loo paper and fold it in half then fold it in half again. Put one of the two folded corners into your mouth and rip off a small section and leave it clasped in you teeth. Now unfold the sheet of loo paper and you will have a nice hole in the middle. Now place your finger of choice through said hole and use your finger to wipe your ass clean, remembering to clasp firmly any lodged tagnuts. When finished wiping simply grab the paper with your free hand and wipe the offending finger clean. Now that bit of paper you kept in your mouth earlier now comes in very handy for cleaning under the finger nail, remembering of course to use your spare hand to retrieve paper from mouth, otherwise you end up with shi**y breath.
Hope this is of help and remember you can also carry two or three spare sheets incase you get caught short again Thumbs Up Whistle Laughing
Brian.
Post #99426 11th Nov 2011 8:07pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #99427 11th Nov 2011 8:08pm
K9F
Lorryman,
You must be bl00dy joking....Curry night in Weatherspoons Southsea..... quaffing Stowford Press, Magners and Strongbow and any other 'Central heating for tramps' cider I can lay my hands on.....Full English breakfast in the hotel at 7am next morning.....by 8am latest I can be found in trap 3 pooing like a ferret.....I could theoretically pebble dash a 10 foot high wall at 15 paces.....
Pull between legs til brown line stops is the only well-proven method to get one's crimper clean.... Bow down Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #99446 11th Nov 2011 9:40pm
Lorryman100
K9F wrote:
Lorryman,
Ehmmmm.....is that not a bit dangerous in your working environment, what with all them sailor boy types hanging about? Especially with you in the take me now pose you describe above? Whistle
Post #99448 11th Nov 2011 9:46pm
K9F
Damn 'Daisychainers' get veverywhere....Portsmouth is awash with 'em. Double lock the door with another Ex Crab (Ex-RAF such as myself) on sentry duty outside with a pickaxe handle normally frightens them off!
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #99462 11th Nov 2011 10:44pm
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
bet you wish you hadn't asked......................
Post #99464 11th Nov 2011 11:15pm
K9F
Rolling with laughter Ask he did though! Laughing Think this thread was finished anyway! Tried Lorryman's theory out this morning (no alcohol consumption last night) it does in fact work a treat! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #99480 12th Nov 2011 9:15am
cobs
for a thread with a fairly unpromising title, actually it's turned out OK - possibly a tad more detail than we might have anticipated Laughing
Post #99516 12th Nov 2011 4:46pm
Page 2 of 2 <12
