Home > Technical > Prop Shaft Questions
LJMARSDEN
United Kingdom 2006 Defender 90 Other HT Java Black
I recently converted my 06 90 to a V8. I have a problem with the rear Prop having to be fully collapsed in order to instal it. This may be down to the fact that the TC & Gearbox has been pushed back. However, the mounts are untouched?
My questions are:
With only being moved down the chassis a centre meter or so, has this prop always been an incorrect fit?
When can I expect it to go pop? (if this is such a problem) Rolling with laughter
And
Are the Prop Flanges different between models years, Axles and such?
There are some off the shelf props with their lengths listed. I want to get lucky and simply pick and choose one that is a few centre metres shorter.
List of a couple Props:
Puma 90: LR044296 @ 65cm
"4 Cylinder" 90's: FRC7732 @ 63cm
Current Prop, 300tdi/ TD5 rear:FRC8393 @ 68.5cm 4.0 V8 Defender 90
My Instagram
Post #992809 16th May 2023 6:41am
rallysteve
Assuming yours started as a Td5? Have you retained the R380/LT230 in the same location as the original installation?
On my V8 conversion I went from an LT77 to an R380 and used the transfer box/gearbox mounts as per a 300tdi then used those to set the locations of the engine mounts. I then used a pair of TD5 propshafts.
All of the flanges are the same across models/variants.
Post #992817 16th May 2023 8:25am
LJMARSDEN
Yes, same mount positions for the TC & gearbox. Keep in mind on the later chassis the mounts are slotted for the bolt so there is movenent available. Potentially different on Pre TD5 chassis'.
Now I know that the flanges do not change I'll have a think about using the shorter Puma rear Prop.
Reason for the need to move the gearbox & TC back was due to the need to fight for fitment between the accessory system and the PAS box. 4.0 V8 Defender 90
My Instagram
Post #992828 16th May 2023 10:24am
Dinnu
Re: Prop Shaft Questions
By "4 Cylinder" I assume that you are referring to 200tdi and earlier. If yes, I am pretty sure that the Puma rear prop is shorter than the 200tdi, so check your source of information. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992829 16th May 2023 10:29am
LJMARSDEN
"upto 1986". Was the 200Tdi in production then? 4.0 V8 Defender 90
My Instagram
Post #992830 16th May 2023 10:38am
Dinnu
For sure not. I found "FRC7732 - DEFENDER 90 REAR PROPSHAFT 666FOR 2.25 & 2.5 UP TO CA252578 CHASSIS NUMBER". But I am not aware that there were any changes to chassis or gearbox/TC (except suffixes). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992832 16th May 2023 10:56am
LJMARSDEN
Hmm, well wouldn't it be inconvenient the sellers stating the wrong dimensions... 4.0 V8 Defender 90
My Instagram
Post #992921 17th May 2023 6:07am
Dinnu
From /gwynlewis4x4.co.uk :
200tdi: Working length :- 667mm + – 8mm Fits :- Defender 90 Rear 2.5/2.5Td/200Tdi
300tdi/td5: Working length :- 710mm + – 8mm Fits :- Defender 90 Rear 300Tdi/Td5
Puma: Working length :- 645mm + – 8mm Fits :- Defender 90 Rear PUMA TDCI Td4 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992926 17th May 2023 7:08am
LJMARSDEN
I certainly Trust GwynLewis over where I first found the info...
Still looks to me the Puma model year will do. Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #992927 17th May 2023 7:25am
Dinnu
Just note that by default, Puma 90 rear shaft is out of phase (diff yoke and transfer case side yoke are not aligned, just like the front prop shaft of all years). This was apparently done to reduce 'vibration' since the diff and TC are not parallel on a Puma (nose up engine install). If your TC (and engine) are installed horizontally, then you need the yokes to be aligned, so they work together and get constant speed again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992934 17th May 2023 8:17am
LJMARSDEN
I'm considering a Gwyn Lewis product would they be deliberately out of phase too? I've not yet read through all info their site. 4.0 V8 Defender 90
My Instagram
Post #992935 17th May 2023 8:26am
Dinnu
When I read the description on their website for the Puma rear prop shaft, they say "Phased when required to reduce vibrations.". So seems like they can tailor it for specific needs.
https://gwynlewis4x4.co.uk/product/puma-90...-mega-610/ 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #992936 17th May 2023 8:39am
LJMARSDEN
I'll have to measure the distance this weekend and get intouch with them. Thumbs Up
Thanks Dinnu Thumbs Up 4.0 V8 Defender 90
My Instagram
Post #992938 17th May 2023 8:45am
