60 Amp glow plug fuse
I've been having some engine problems and have read some fault codes. Amongst others I was getting P037D-29 Glow plug relay sense circuit and was unable to clear the fault code (engine was starting fine).
After a bit of seraching I found that this 60 amp fuse is to do with the glow plug and was missing on mine.
Ive installed another fuse and now the fault is gone, however the main cable from the fuse does get warm (but can be held in the hand no problem) I'm wondering if there could be a reason why this fuse has been removed in the first place any sugesstions appreciated.
1st May 2023 7:35pm
NickMc
Have you got a shorted out glow plug or broken one? They can be a swine and snap off in the engine bay, the other common one is the wire at the front of the engine the supplies power down to them wire nut thing fails.
18th May 2023 12:45pm
hank
Is it warm all the time or just during the glow cycle at startup? It is controlled by a timer and relay so even if there is an issue with the circuit it should be switched off after the startup glow cycle> 110 XS Double Cab
18th May 2023 2:52pm
mrfirepro
thanks for the help. I sorted my main problem out with the injectors and I've removed the fuse as it does not seem to make any difference to anything.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
