Home > Maintenance & Modifications > Td5 windscreen washer pump
Sepulchre
United Kingdom 2006 Defender 90 2.5 TD HT Cairns Blue
Hi all,
My windscreen pump has failed (confirmed by switching power from rear screen pump).
How do I remove the old pump before fitting the replacement? As far as I can see it’s only held in the washer reservoir by the rubber grommet, so is it just a case of pulling it out and switching the new one in?
Really basic question I know but wanted to check before just yanking it!
Thanks!
Post #990794 29th Apr 2023 12:02pm
landy andy
Just pulls out.
Post #990796 29th Apr 2023 12:08pm
geobloke
Yup as above. You can get to it through the headlamp hole. Might be a good time to upgrade to the Optimill washer pump and nozzle upgrade Thumbs Up Worth it...!
Post #990797 29th Apr 2023 12:10pm
Sepulchre
Thanks guys figured as much, when I was checking to work out where the problem was I had it all apart to access the power connectors, gave the pump a yank but at that point but wasn’t for budging. I’ll give it more wellie this time.
Optimill - yes very tempting, but wow what a price! I went for an OEM one from rimmer bros for £8, yeah that’s going to do fine Laughing
Post #990798 29th Apr 2023 12:18pm
Screbble
If you haven’t done so already, replace, or better still remove, the non-return valve in the pipe 👍
Post #990807 29th Apr 2023 2:43pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
There is a rubber grommets pushed into the fluid bottle that the pump pushes into. When it's cold it's hard and tough. Try and flush the bottle out when all stripped. As other have said, renew the no return valve - they get clogged. The rear washer jet non return was in the headlining in mine. 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #990835 29th Apr 2023 11:48pm
