Home > Technical > Puma Dash - Bare White wire ? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17540 |
I can tell you that my '07 Puma doesn't have it. Is it aftermarket?
24th Apr 2023 9:41am |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 204 |
I think that might be the aerial for the remote central locking. Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
24th Apr 2023 9:49am |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 514 |
i thought that also but then i seen it on the other guys youtube video to Shane |
24th Apr 2023 9:50am |
Oh that sounds good, i was wondering where the ariel was for it when installing the module. In the vid the guy just pushed the dash on over it |
24th Apr 2023 9:51am |
Well, if it is the aerial for the CL, it looks entirely different and is an entirely different location to mine!
What year is the vehicle and what version of 10AS is fitted? |
24th Apr 2023 11:09am |
I am probably wrong but I thought the white wire looked like the wire that is extended in this link.
http://defender90xs.blogspot.com/2014/11/r...nsion.html Was hoping somebody more knowledgeable would clarify, thanks @blackwolf Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
24th Apr 2023 11:23am |
I'm inclined to agree with you. You haven't answered my question about the year of the vehicle, but the one in your link is said to be a 2010 vehicle. I also seem to recall that others on this forum have referred to the aerial on vehicles later than mine running towards the centre of the dash, whereas on mine and other early vehicles it either just dangles from the 10AS or runs towards the RH windscreen pillar (and the preferred means of extending it on the early vehicles is to extend it up the RH windscreen pillar). Also on the early vehicles it is not white.
So on balance I think think you are right. |
24th Apr 2023 11:56am |
sorry black wolf, mine is a bit of a Frankenstein, its 1989 but I've fitted a puma 2.4 loom to it
I like the idea of the A - Pillar route might extend mine. Thanks for all the replies guys Shane |
24th Apr 2023 12:59pm |
Ah, I saw 1989 in your avatar but thought is couldn't be the vehicle since it is well pre-Puma!
Just remember that the greater the range on your remote, the greater the chance of accidentally unlocking your vehicle without realising it if you inadvertently squeeze the button in your pocket. Mind you, even with my antenna extended, I usually have to be within touching distance of the vehicle for the plip to work (or do the mysterious "press the plip against your head" trick, the one everyone says cannot make a difference but demonstrably does). |
24th Apr 2023 2:02pm |
its 89 for the tax man lol, i started off with a 89 and basically everything puma on it, 56 euro euro road tax as opposed to 2500 euro which i think the pumas are here
24th Apr 2023 2:08pm |
