Home > Technical > Light Switch
rebarrob
2011 Defender 90 Puma 2.4 HT Santorini Black
Light Switch
Surprised Hello, I have just bought a new defender and am a bit confused as to the where the main light switch is positioned just next to the ignition. I am finding when you need to take the key out you have to switch the lights off. Can you move the light swicth or put the ignition on the other side of the steering column. Advise as to any ideas would be accepted.
Post #98922 9th Nov 2011 11:51am
ibexman
I dont have this problem, ???
Post #98934 9th Nov 2011 2:12pm
I always thought of that as a neat bit of low tech design to remind you to turn the lights off when taking the key out, instead of some annoying bong or chime Smile
It should still be possible to remove the key with the lights on if you really need to though Confused If you're finding it a struggle, then just turn them off, remove key and turn them on again? Darren
Post #98935 9th Nov 2011 2:17pm
pom
why do you want to leave the lights on ?
You take the keys out. Leave the lights on and then do what - turn them off by any chance ?
I must be missing something.....
Pom
Post #98938 9th Nov 2011 3:04pm
The steering column shroud has provision for an identical switch on the opposite side to the light switch, so if you really wanted to you could move the switch from the left of the column to the right.
I have in mind using a modified second lightswitch mounted on the right for auxiliary purposes at some time in the future, making use of this "feature".
Post #98959 9th Nov 2011 4:18pm
I'm thinking this is your first land rover ?
there are hundreds more "features" you will find as you get to know yours
Post #99027 9th Nov 2011 8:06pm
rebarrob
Just think it make's it awkward sometimes to put the key in the ignition. On another point I find the headlights off cars coming from behind seem to reflect off the front window making it look like a car is coming from another direction. Would anyone recommend tinting the back windows. Think the jeep is brill and looking forward to going offroad
Post #99032 9th Nov 2011 8:43pm
landy andy
Two points
First, never ever ever call it a "jeep", it is a Land Rover Defender.
Second, tinting rear window makes it worse. You'll get used to it.
Andy
Post #99033 9th Nov 2011 8:47pm
rebarrob
Embarassed Sorry, I mean defender
Post #99035 9th Nov 2011 8:53pm
110SEB
I'll forgive the 'J***' comment once and once only.
As for tinting we have 70% on everything behind the B pillar. It's great but vision is limited somewhat. I've had it from day one and am used to it. Never noticed your problem with lights from behind so perhaps it does work.
Welcome Thumbs Up
Post #99045 9th Nov 2011 9:28pm
think the headlight switch is bad, wait until your spine bends and stays that way to suit the LR seats and pedal position....
And don't even think about your elbow on the door Laughing Laughing Laughing Laughing
Welcome! Thumbs Up
Post #99047 9th Nov 2011 9:34pm
rebarrob
Diesel_Jim, I am only 5'6" so actually fit in the the cab. I can see that it is quite compact. My brother has a TD5 and says there is a bit more room because the dash is further forward. Love my Defender, but the wife says ' what the #### is that I have bought. I have driven a Disco 4 for the last 12 months.
Post #99060 9th Nov 2011 11:18pm
My daily driver is a shogun, nice comfy driving position.
I had to go to Heathrow today in the 110, even with the drivers seat pushed right back my knees were quite "bent".... but I love it!
Post #99061 9th Nov 2011 11:21pm
Jamie - make yourself some seat runners or pack washers on the rear fixing so that the slider is not hitting the join.
Post #99072 10th Nov 2011 7:35am
I might try the washer modification. I made some seat runners a while back but the extra height of the seat (OK, only 3/4", using box section) ended up with me looking directly at the sunvisor (i'm quite large... 6'5")
Post #99073 10th Nov 2011 7:48am
