![]() | Home > Technical > Light Switch |
here you are you can move the light switch to the opposite side, in the place were should be installed the AUX or FOG switch. ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
Question........
When I have my headlights on and then turn the ignition off the headlights go off and only the side lights stay on..... so the whole removing the key with the headlights on wouldn't work anyway? Is it the same with you chaps? Glyn ![]() ![]() |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
Yes. Same with all vehicles isn't it?? You cant have the actual 'headlights' on with the ignition in the off (lock)position, it mearly leaves the sidelights on, as if the switch stalk was in first position on normal use. The only way to bypass this to get the lights on with the ignition off, would be to hold the 'flash' switch on. If the aim was to get the sidelights on with the keys out of the ignition, you need to turn the lights off, turn the ignition off and remove the key, then turn the sidelights back on. ![]() |
you could put some curtains up and tie them back in the daytime ![]() 1968 1/32 scale Britains 109 Pick up. |
