Home > Tdi > TDI 200 A Frame Ball Joint
cykoh85
Malaysia 1990 Defender 110 200 Tdi SW Santorini Black
Hi all, how to fit the A frame bracket (as per picture)?
Thank you.
Post #989342 18th Apr 2023 11:04am
geobloke
Hello.
Which bracket are you referring to? See here: https://www.lrworkshop.com/diagrams/land-r...oint_52634
Post #989343 18th Apr 2023 11:23am
At a guess, this one:
(Photo from OP's gallery).
You do up the bolts?
Post #989356 18th Apr 2023 12:38pm
cykoh85
geobloke wrote:
Hello.
Hi Sir, this is A frame ball joint bracket, attached with the rear axle.
Thanks Smile
Post #989357 18th Apr 2023 1:03pm
cykoh85
No, because it cannot fit at all after I put in the upper bolts, sad. But i did use the hammer try n knock a bit just now, looks ok. Will continue tomorrow as already dark here.
Post #989359 18th Apr 2023 1:05pm
geobloke
OK so that is a Salisbury type rear axle. You need to bolt down the flat bracket to the axle first then insert the ball joint and do up the nut from the side. It is a pain but that is the only way to do it.
Post #989373 18th Apr 2023 2:20pm
cykoh85
Ok, but the problem was when I bolted the bracket to axle 1st, the upper bolt (brushes) very very difficult to align it, and the brushes quite heavy too...hahaha.
so I tried the other ways round, align upper 1st (loose as have not tighten it), then 2nd only come to axle bracket.
thanks bro!
Post #989376 18th Apr 2023 2:40pm
geobloke
OK I need a photo to see what the problem is. Could you fix the axle plate in to position then lower the ball joint into position. Take a few photos of the bit that is rubbing. Thumbs Up
Post #989378 18th Apr 2023 3:17pm
cykoh85
Ok. By the way, do you mean lower the ball joint into position is unscrew the castle nut 1st? 2nd pic was bolted the axle plate, then upper (brushes side) become unfit Sad
Post #989381 18th Apr 2023 3:35pm
cykoh85
Dear all
Update: finally able to fit all the parts. just jack up the axle a bit and use a hammer knock the ball joint from top and the castle bolt able to fit the hole.
thank you all for your info. Smile
Post #989436 19th Apr 2023 6:30am
