Home > Puma (Tdci) > 2011 Landrover 2.4 diesel TDCi not starting |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1785 |
There is immense talent and knowledge on this forum and I'm sure someone will be along soon to help - from a non expert position, did you fill the fuel filter and then bleed the air out of the system?
Is it possible you've had a faulty vcv /crank position sensor to cause the intermittent fault and now it just needs bleeding through? Good luck Keith |
14th Apr 2023 7:20pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2029 |
When you say you bypassed the immobiliser, what did you do?
The 10AS alarm module sends a signal to the engine ECU to allow it to start, without that signal the engine won’t start unless the immobiliser has been mapped out on the engine ECU. Also with the new ECU, did you pair it with the 10AS, this needs to be done to enable the engine to start. Did you remove the instrument cluster (IPAC), disconnect the wiring connector, then without the cluster connected bridge pins 3 and 4 of the wiring connector and try to start the engine ? I say this as a cluster fault can stop the 10AS alarm communicating with the ECU. If you have not done the above that’s the first thing to try, the next is to check the ignition switch which can also cause starting problems. |
14th Apr 2023 8:57pm |
peanutbob Member Since: 12 Feb 2009 Location: UK Posts: 293 |
Do you have central locking? If so, change both remote batteries just to be sure - it’s quite a common occurrence that non starting is caused by flat remote batteries and for a few quid it’s worth doing annually. Even the new defenders fob batteries are flat in 8 months.
14th Apr 2023 9:24pm |
Bluericky Member Since: 26 Jun 2014 Location: Cornwall Posts: 647 |
Does this not sound like a faulty ignition barrel ? I had similar a few years ago and it was all or nothing, sometimes it would even cut out whilst driving .
Pretty well documented fault and certainly worth a try https://www.instagram.com/hustynminepark/ |
16th Apr 2023 12:40pm |
On second thoughts, I can't remember whether mine cranked or not , possibly not. Worth doing some research https://www.instagram.com/hustynminepark/
16th Apr 2023 12:42pm |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 744 |
Yes it could well be ignition barrel, I had similar problems earlier this year, cured by replacing the barrel.
In fact my 2.4 130 has had two new ignition barrels in 117k miles. |
16th Apr 2023 12:54pm |
sdev Member Since: 14 Apr 2023 Location: Derby Posts: 17 |
Thanks everyone for your comments. There’s a couple in there that might help in getting to the bottom of this daunting issue.
I have also got high pressure ECU warnings. I’ll get the specifics later. Final thing to throw into the mix is the clutch operation is very poor. Is there any way that the clutch power reduction switch is interfering with the starting? Thanks all so much for your guidance. |
17th Apr 2023 8:25am |
Folks - here are the codes.
Click image to enlarge They sound scary. Note we’ve checked the injectors (off the vehicle) and they work to standard and we’ve popped a new injection pump on. Last edited by sdev on 17th Apr 2023 10:49am. Edited 1 time in total |
17th Apr 2023 8:49am |
See 3rd post down on this topic from member Naks. https://www.defender2.net/forum/topic77690.html?highlight=p1293
He has provided links to a transit forum for people with similar fault codes. Ignition switch was one cause, damaged loom the other, but given defender ignition switches are a know issue I would replace that first, some good how too guides on here if you search. PS. You only need to replace the switch at the bottom of the ignition, not the whole ignition barrel. |
17th Apr 2023 11:41am |
Thanks everyone for your comments. We tried the ignition switch change but unfortunately without a positive result.
So we still have a vehicle that simply won’t start. We’ve thrown virtually everything at it but we must have missed something. Any other thoughts from esteemed friends here would be gratefully received. |
22nd Apr 2023 6:53am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2420 |
Is your new PCM immo off? Puma 110" SW
22nd Apr 2023 1:08pm |
After more investigations, sending the immobiliser away (checked and found to be working) and changing 4xinjectors for Denso originals, the car is still not starting.
The fault codes still state issues on the HP side of the engine, bank 1 and bank 2. We have changed all of the following 1. Fuel filter WJI500040 2. PCM (ECU) NNN501630 3. Valve assembly (VCV) LR009837G 4. Crankshaft sensor LR004396 5. Camshaft sensor LR048186G 6. Injector function test x 4, passed 7. Gasket LR004381LR 8. Fuel pump assembly LR010210LR 9. Ignition switch 10. Immobiliser system sent away, checked and stated as OK 11. Four new fuel injectors LR006803G Any fresh ideas? Possible solutions? |
12th May 2023 3:04pm |
Siwynne Member Since: 04 Nov 2016 Location: West lancs Posts: 578 |
Sounds silly but …..Are you definitely getting diesel to the injectors when cranking?
12th May 2023 3:52pm |
In your first post you stated
So that seems to be the issue, have you checked the wires and connectors going into the sockets that the relays plug into ? Or any other of the fuses and earths etc that you may have disturbed when changing the relays ? My thoughts are that something is not making contact properly, in changing the relays it made temp contact again, however with a few starts and vibration when driving it’s now not making contact. |
12th May 2023 4:39pm |
