Home > Maintenance & Modifications > Front mud flap bracket location
TomB8
United Kingdom 1994 Defender 110 300 Tdi HT Arles Blue
I would like to add front mudflaps, but cant for the life of me figure out where the bracket should go.
I know its supposed to bolt to the front outrigger, but the factory location for the outer bolt hole clashes with the outrigger/bulkhead bolt.
I have searched and searched but cant find a photo of where the bracket is supposed to mount.
Can anyone help, please? Apologies for the poor imagery.
or?
Post #988421 10th Apr 2023 12:55am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
The 2nd picture is the orientation on mine. They were not fitted, but it had the holes and rivnuts fitted to the outriggers though.
I thought they came as standard?
If they don't then mine are fitted the way a previous owner decided. Your first picture might be better if you have issues with mud up the doors. Craig.
“Don't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #988438 10th Apr 2023 8:57am
Retroanaconda
These are the factory holes on my 90 chassis - seems to be well clear of the bulkhead bolt?
Post #988468 10th Apr 2023 11:32am
TomB8
I see, that's really helpful, thanks both. Maybe I need to drill extra holes in the brackets then. Seems weird, or maybe I'm missing the obvious. I'll go under and have another look when the ground isn't soaking.
Retroanaconda, are those Gwyn Lewis shields you have on without mud flaps? If so, what do you think of running them like that? I'm guessing you haven't found the need for flaps with the shields.
Post #988515 10th Apr 2023 5:37pm
Cragster69
Some not so great pictures of mine fitted. Craig.
www.scotgrc.co.uk
Post #988520 10th Apr 2023 6:00pm
Retroanaconda
No, they’re my own home-made version but the same principle. They keep the mud off the bulkhead and chassis outrigger.
I’ve never found the need for mud flaps on any Land Rover.
Post #988563 11th Apr 2023 7:51am
marsie
England 2010 Defender 110 Puma 2.4 XS CSW Galway Green
The standard position does overlap the pressed hole in the outrigger. There are usually a couple of spacers under the bracket to allow it to sit flush with the pressed hole. 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE*
2010 110 2.4 XS station wagon
Post #989377 18th Apr 2023 1:49pm
