Home > Maintenance & Modifications > Front mud flap bracket location |
Cragster69 Member Since: 15 Jun 2021 Location: Scotland Posts: 193 |
The 2nd picture is the orientation on mine. They were not fitted, but it had the holes and rivnuts fitted to the outriggers though.
I thought they came as standard? If they don't then mine are fitted the way a previous owner decided. Your first picture might be better if you have issues with mud up the doors. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
10th Apr 2023 8:57am |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2647 |
These are the factory holes on my 90 chassis - seems to be well clear of the bulkhead bolt?
Click image to enlarge |
10th Apr 2023 11:32am |
TomB8 Member Since: 17 Nov 2022 Location: West Sussex Posts: 115 |
I see, that's really helpful, thanks both. Maybe I need to drill extra holes in the brackets then. Seems weird, or maybe I'm missing the obvious. I'll go under and have another look when the ground isn't soaking.
Retroanaconda, are those Gwyn Lewis shields you have on without mud flaps? If so, what do you think of running them like that? I'm guessing you haven't found the need for flaps with the shields. |
10th Apr 2023 5:37pm |
Click image to enlarge Click image to enlarge Some not so great pictures of mine fitted. Craig. “Don't believe everything you read on the internet.” ― Abraham Lincoln www.scotgrc.co.uk |
10th Apr 2023 6:00pm |
No, they’re my own home-made version but the same principle. They keep the mud off the bulkhead and chassis outrigger. I’ve never found the need for mud flaps on any Land Rover. |
11th Apr 2023 7:51am |
marsie Member Since: 17 Nov 2011 Location: sheffieldish Posts: 532 |
The standard position does overlap the pressed hole in the outrigger. There are usually a couple of spacers under the bracket to allow it to sit flush with the pressed hole. 2000 90 TD5,galv chassis, d2 axles ,Bas remap , alisport intercooler , d2 transfer box , side windows-more to come-much more!! *GONE*
2004 110 TD5 Double cab. *GONE* 2010 110 2.4 XS station wagon |
18th Apr 2023 1:49pm |
