Home > Wheels & Tyres > Will these tyres fit?
spudfan
Ireland
Defender 110 200 tdi fitted with steel wheels 5.50f x 16 currently fitted with 7.50 x 16 tyres.
Would it be possible to fit 235/80/16 tyres on these rims? Sounds a silly question but I just measured the spare on the 110 and though marked 7.50 x 16, it is wider than the 7.50 x 16 tyres fitted to the road wheels but not as wide as the 235 tyres. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #988290 8th Apr 2023 7:07pm
Mdm
not ideal they should be on 6.5 rims for best handling.
7.50 work ok on std 5.5 rims though
Post #988294 8th Apr 2023 7:11pm
jimbo55
I ran 235/85’s on 5.5” rims on my series for ages, no issues but probably isn’t recommended. Toyo recommend a 6-7.5” rim for that size
Post #988295 8th Apr 2023 7:15pm
spudfan
Ireland
I like the 7.50x16 tyres but they are getting hard to find. I currently have Goodyear Wrangler Radial 7.50x16 and am very pleased with them. Unfortunately they are no longer available. Goodyear do a similar tyre in 235/85/16, thus my question. 1982 88" 2.25 diesel
Post #988296 8th Apr 2023 7:22pm
markb110
i assume that those wheels are tubeless and don't require a tube.
Tubeless tyres are not smooth on the inside from memory and hence will wear the tubes until they suddenly let go....
Lets just say that was a brown trouser moment on the A303.
The next day they got changed for a set of Wolf wheels
Post #988302 8th Apr 2023 8:32pm
spudfan
Ireland
The current steel wheels are tubed. Just looking for options for later. Over here at the annual MOT you get a warning when your tyres reach 6 years of age, irrespective of wear or condition. The 7.50x16 tyres on my 110 just passed 6 years of age before the test so I got a notification on the cert about the tyres. The 110 does not do many miles so there is little wear and no cracks in them.
As of yet this is not a fail but knowing insurance companies I would not want to be involved in an accident and have them use tyre age as a contributory factor.
I might go Wolf wheels and a change to 235/85/16 tyres. Was it a straight forward change fitting the Wolfs on the 110? 1982 88" 2.25 diesel
Post #988312 8th Apr 2023 9:43pm
markb110
My 110 was a 300tdi and so fitted on the studs without issues.
I don't know about the 200, i know that some had to have longer studs fitted due to the thickness of the Wolf rims.
Post #988316 8th Apr 2023 10:38pm
spudfan
Ireland
I suppose the rear drum brakes would need to be factored in. 1982 88" 2.25 diesel
Post #988318 9th Apr 2023 12:01am
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
No problem to mount 235/85r16 on standard 5.5 steel rim.
Post #988524 10th Apr 2023 8:06pm
