![]() | Home > Technical > PUMA Second battery holder - Split charge system |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4259 ![]() ![]() ![]() |
You can fit 2 standard size batteries in easily if you remove the jack and chock etc. I had to make my own tray, which meant learning to use a Mig welder I borrowed. I can’t believe no one has made one commercially. There is room behind the batteries for the VSR too. 2007 110 TDCi Station Wagon XS
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1110 ![]() ![]() ![]() |
One tray I can think of is gmb-mount (https://shop.gmb-mount.de/DEFENDER/Elektrik/Doppelbatteriesys./). I think there are other makes, too.
I made my own from aluminium sheets and profiles. It's not too hard to do: https://www.kraxlr.de/makingof.html#electrics More pictures (poor quality, but you get the idea). Uses the original bolts from underneath, and the screw-in clamps from above to secure the batteries. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1314 ![]() ![]() ![]() |
The Flatdog tray might do it - I made my own for original battery and a Numax
https://www.flatdoguk.com/defender-twin-battery-tray~93 |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
gywn lewis one works a treat in a puma
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 72 ![]() ![]() ![]() |
Thanks you all for the replies and ideas - mecfrank your photos are really useful. Need to do a proper translation from German, but is the GMK says something about the 300tdi? Isn’t the puma box slightly different, but perhaps it’s just about making the floor flat.
I might give flatdog a shout and see what they think - I need a roof rack and high level internal shelf for the 90 and am almost decided on their kit for those. They seem to be pretty helpful. Will let you know how I get on with a solution. |
Marcassin Member Since: 18 May 2022 Location: Aveyron Posts: 5 ![]() ![]() ![]() |
Hi Macfrank, thanks for the photos. Would you share measures and plans ? I am really interested to try it out ? |
