Home > In Car Electronics > Light bar wiring options
Drevil
2011 Defender 110 Puma 2.2 USW Indus Silver
Just about to hang a lightbar from the front of my rack and likely run the wires under the door seal and into the cabin…..but my quick question is, what other ways and means have people used? Any obvious pitfalls?
I don’t have a snorkel so can’t run that way.
Any images greatly appreciated.
Post #988200 7th Apr 2023 10:58am
Tr90
United Kingdom 2000 Defender 90 Td5 CSW Alveston Red
I ran mine along the gutter to the back and then down the ladder. The wire enters the car through the number plate light plinth. And then to the relay in the battery box.
Post #988223 7th Apr 2023 6:58pm
lolo
Switzerland 2008 Defender 110 Puma 2.4 CSW Keswick Green
I have routed mine via the upper front corner of the passenger door, than down the A pillar behind the plastic trim, than under the dash, under the front mat to the battery box.
It helps to use flat wire.
Other route would have been to go down the windshield along the rubber seal than into the engine bay via the back corner of the hood. Than connected via a relay to the alternator.
Post #988405 9th Apr 2023 10:08pm
donmacn
I did the “unthinkable” about 5 years ago and made two holes in the roof….
Because they are fitted/sealed through marine deck glands they have given me zero issues at all. And to be fair to myself, because the car began life as an airport aux. vehicle there were already other random holes in the roof (just not in the right place!) which have given me zero issues for about 22 years… Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #988447 10th Apr 2023 10:08am
