Home > Puma (Tdci) > Puma 2.4 Coolant Leak
JohnT43
Hi guys, I’ve got a minor(ish) Intermittent leak, somewhere in the cooling system. Checking it daily (vehicle is my daily driver), some days I’m topping only it up with about a cup of water, other days half a litre….just can’t locate the Censored Mad I’ve put one little bottle of K-Seal in and that held it for a couple of months, but reluctant to do the same again though.. “Shirley” the more of this gunk I pour into the system, the bigger the likelihood of bunging up the coolant runs in the engine, etc? Anyone got any advice on this? Confused
Thanks in advance for you received wisdom chaps! Bow down Bow down Bow down
Post #987943 4th Apr 2023 9:18pm
matchap801
United Kingdom 2009 Defender 90 Puma 2.4 CSW Zermatt Silver
I have a kit like this below - really useful to find external leaks, test when cold and warm .
https://www.ebay.co.uk/itm/392977869039?mk...media=COPY 2009 Defender 90 CSW 2.4 TDCI.
Ex Army Mechanic still living the dream.
Post #987971 5th Apr 2023 7:37am
Ianh
The heater valve can leak and drip especially when heater is on hot. So worth looking at that, several topics on the issue on here and an easy job to replace.
The main radiator can leak, especially on the near side engine bay side. This can be hard to spot as there is a lot of piping and plastic shielding in the way. A tell tale is orange / pink staining on the rad.
If that needs replacing a Nissens replacement is a good price and better quality than a replacement from LR.
Post #988004 5th Apr 2023 12:18pm
spudfan
Ireland
It can be as simple as a leaky join where a clip is not fully tight. It could be at the water pump which which you should be able to see with the bonnet up. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #988087 6th Apr 2023 12:19am
