Home > Technical > Exhaust fumes/connection
badshotleigh
Hi all,
Defender-noob here so go easy!
Just bought my first at the weekend - 1996, had a replacement 300TDI engine put in it a few years back.
The previous owner didn't give it much love of late - low oil, coolant, power steering fluid etc etc so I've done all those bits.
I've noticed it gets mighty stinky when driving so on a further bit of investigation noticed the exhaust isn't connected - see the attached photo.
I've tried loosening off the bolt and pushing them back together but there's a fair bit of resistance.
Any support/tips would be great. Being new to this there is plenty to learn.
Cheers,
Will
Post #987973 5th Apr 2023 7:09am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Pretty sure that is the 200tdi manifold/exhaust. The 300tdi has a 3 stud triangular flange that the down pipe mounts to. If I remember correctly the 200tdi downpipe also bolts to the engine block via a bracket midway down the frontpipe so it could be this that is stopping you from moving the exhaust into the correct position?
Post #987977 5th Apr 2023 7:31am
I Like Old Skool
By the way, I guess this also means you have the 200tdi engine?
Post #987978 5th Apr 2023 7:32am
badshotleigh
Thanks for the replies - I am still trying to get to the bottom of the story. The garage paperwork just says 'engine'!
Can I loosen off the bracket, loosen off these bolts, slot if back on and do everything up again? Does it need a bit of grease to create a seal?
Post #987979 5th Apr 2023 7:35am
Can you share wider picture of the engine bay? Darren
Post #987981 5th Apr 2023 7:39am
Dinnu
200tdi had top mounted turbo on a Defender, similar setup as the 19J with exhaust above inlet manifold. Different from a 300.
Interesting the location of the EGT probe. Would that not be cooler after the turbo (expansion from turbine)? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #987983 5th Apr 2023 7:57am
badshotleigh
Here you go
Post #987986 5th Apr 2023 8:00am
htb2
Wales
200 Tdi, defender spec for sure.
Post #987992 5th Apr 2023 8:35am
badshotleigh
A quick scrabble around underneath to look at the other part of the exhaust reveals it isn't attached.
Post #988002 5th Apr 2023 10:55am
Dinnu
There is a triangular coupling further down the exhaust pipe. You might have to loosen the 3 bolts just enough so that you can lift the down pipe enough to connect to the turbo outlet pipe. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #988020 5th Apr 2023 1:08pm
Mdm
they are always fun to get them to line up.
best way is on a ramp.
with a proper downpipe clamp (new)
loosen all the exhaust and work your way down from the front to the back aligning as you go .
the downpipe bolts rarely line up on aftermarket exhausts
Post #988029 5th Apr 2023 1:46pm
badshotleigh
Thanks - is this a relatively easy job? Also, that bottom part isn't bolted to anything so it's just going to rattle loose I think - are there specific bolts to re-attach this?
Thanks for taking the time to help.
Post #988047 5th Apr 2023 3:29pm
badshotleigh
If anyone could help me out with the bolt sizes for re-attaching that would be great - I think they should be m10s? m10 50s?
Post #988052 5th Apr 2023 5:18pm
I Like Old Skool
That is the proper clamp, and looks in reasonable condition. Maybe just get a new bolt for it if the old one is suffering?
Post #988089 6th Apr 2023 12:41am
I Like Old Skool
Just looking at the engine bay pics and there's something wrong here. What year is the vehicle? That looks like a very original 200tdi engine bay installation, everything is in the correct 200tdi location, even the fuel filter on the bulkhead and the power steering bottle are different on a 300tdi. Also the fan cowling is very deep, suggesting that the gearbox is the LT77 from pre-300tdi (the 300tdi was sat much further forward, to make room for a longer R380 gearbox I believe).
Your car looks like it has always been a 200tdi so would not be a 1996 vehicle unless it has had an odd military past or been a LR factory vehicle before being registered?
Post #988090 6th Apr 2023 12:55am
