Home > Puma (Tdci) > Removing Steering Guard, Stuck Bolt
jcw
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
I’ve removed the steering guard from my 2007 Puma, however one of the bolts that held the right hand side bracket on refused to budge after removing the nut on the inside, I tied turning the head of the bolt with a breaker bar and it’s snapped the head off Crying or Very sad
I’ve tried the double nut approach to try and wind it out but it just won’t move, soaked in Liquid Wrench over a couple of days, still not moving.
Should this bolt just knock out or is there a thread in the tube it passes through?
Any advice appreciated Thumbs Up
Post #987754 3rd Apr 2023 12:19pm
rustandoil
You just need a bigger hammer! theres no thread in the tube..
In fact the tube has quite a lot of clearance, its most likely stuck in the Panhard rod forging
Good luck
Post #987757 3rd Apr 2023 12:31pm
jcw
Thanks Thumbs Up
In which case I’ll ask my wife to hold the drift whilst I swing the sledgehammer!!
Post #987768 3rd Apr 2023 1:22pm
Dinnu
I would remove the panhard bracket off the chassis. You only need to remove the panhard bolt, and the nut that ties the bracket to the steering box. Should come off easily, as as said earlier, it is probably seized in the panhard rod bracket only.
Then you can use a hammer, which could make it worse as the bolt mushrooms in place. You might have to drill it out. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #987772 3rd Apr 2023 1:58pm
jcw
Thanks Dinnu, I did wonder if that might be the easiest approach and you’re right, it’s already started to mushroom over slightly Rolling Eyes
Post #987788 3rd Apr 2023 4:00pm
Dinnu
If the panhard bracket is out, you can hammer on the thread end of the bolt. All you need is to break the initial grip. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #987800 3rd Apr 2023 5:02pm
jcw
Thanks again Dinnu, removed the panhard rod and the seized bolt knocked out relatively easily with a few hits from a sledgehammer.
One further question, where it mounts to the steering box bolt, should there be a bush of some sort as the bolt is significantly smaller than the hole in the panhard rod?
It doesn’t look so from the parts diagram but wanted to be sure before reassembling.
Post #988195 7th Apr 2023 8:35am
htb2
Wales
No bush req, its a large clearance to allow for L/R tolerances.
Post #988203 7th Apr 2023 10:09am
jcw
Thanks Thumbs Up Wasn’t one in there on removal but always worth checking in case of previous cowboy mechanics!
Post #988205 7th Apr 2023 10:16am
