Home > Puma (Tdci) > 2012 Puma wiper motor and park sensor
NThompson1
United Kingdom 2012 Defender 110 Puma 2.2 USW Santorini Black
Hi All
New to the forum but just reaching out to see if anyone has come across issue I’m having.
I have a 2012 TDCI puma and had been having the wipers playing up and not parking, knowing this is not as easy to get at as my old TD5 I decided to get new parking switch, new spindles and cable at the same time as if having to take dash out might as well change the lot.
Having now changed the lot and now putting back together thought I’d test the wipers before the dash goes back in, they worked the first wipe, parked and blew the 15amp fuse, replaced fuse but now just lifting stalk it blows.
Any help would be much appreciated as all I can think is the parking switch is faulty
Thanks Nathan
Post #986800 25th Mar 2023 5:49pm
HTB
United Kingdom 2012 Defender 90 Puma 2.2 HT Buckingham Blue
Might be worth checking you haven’t overtightened any of the fixings for the spindles or drove cable. Something may be causing the cable to jam, stopping the motor and then blowing the fuse.
Post #987495 31st Mar 2023 9:12pm
NThompson1
Thank you for reply, you’re right by re checking, went back over, cleaned up grease that I had put on the electrical connections from re greasing the cable by accident and all worked.
Thanks again
Nathan
Post #987522 1st Apr 2023 7:29am
