Home > Puma (Tdci) > Low Beam not working one side
jennings
Hi - My first time posting on the forum and also a recent first time Defender owner (2014/110SW).
I've noticed last night that the low beam on the drivers side isn't functioning but high beam is fine. It was all working a couple of weeks ago when I bought the vehicle.
I've taken the bulb out and all seems okay which I guess is expected if the high beam works. I've seen reference to relays but not sure where to find this as it sounded like this was different to what is in the fuse box under the seat.
I've assumed they are standard halogen lamps (wipac quadoptic written on lamp) but don't really know.
Any advice on where to be looking for a problem would be appreciated.
Thanks, Paul
Post #987025 27th Mar 2023 3:50pm
MK
https://www.defender2.net/forum/topic33868.html Puma 110" SW
Post #987026 27th Mar 2023 3:54pm
jennings
Thanks. I had seen this post but wasn't sure if the relay is the issue given the high beam is okay as well as the other headlamp as it looks like they would be shared.
Post #987028 27th Mar 2023 3:58pm
MK
OK. Maybe a faulty bulb, terminal, etc. Try another bulb or test the contact. Puma 110" SW
Post #987031 27th Mar 2023 4:06pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Have a look here, might be your problem?:
https://www.defender2.net/forum/topic2156....iring+loom
Post #987036 27th Mar 2023 4:34pm
jennings
[edit] Found the main relay now (No#4 from link) and have checked that and looks fine as well.
Thanks for the replies. I ordered another set of bulbs anyway though figured if high beam was okay this probably isn't the issue as the bulb looked intact when I took it out (I'm assuming the filiment blows like a regular old fashioned bulb, but this is all new still)
I've had a look around the wiring as best I can and can't see anything obvious that suggests chaffing.
Regarding the fuses and relay side. I've checked the fuses for the low beam and they are fine.
Are there any other components to check outside of the wiring that might explain this? I read something earlier here about separate relays but not sure where to find these.
I have the haynes manual which includes a wiring diagram. To my novice eye I can see the fuses but nothing else inline. Unless the relay is the box shaped thing that plugs direclty into the lamp?
Thanks. Paul
Post #987044 27th Mar 2023 5:47pm
To start with, simply swap the bulbs over between the headlamps. If the fault moves, the bulb is at fault, if the fault stays put, the vehicle wiring is at fault.
There are relatively few wiring or component failures which will affect only a single headlight, so it is most likely to be the bulb, the connector on the back of the bulb, or the wing harness.
Post #987046 27th Mar 2023 6:00pm
jennings
Was the bulb, doh! I clearly don't know how check the bulb properly.
Thanks all for help.
Post #987052 27th Mar 2023 6:39pm
jennings
Looks like I spoke to soon. When I swapped the bulbs it worked but just gone out to start up and now no headlights at all. Presumably what every caused the other bulb to blow has now blown this one.
Think it will be a trip to the garage tomorrow.
Post #987065 27th Mar 2023 8:21pm
