Home > Puma (Tdci) > LR031367 Bracket And Bearing replacement
humby
United Kingdom 2015 Defender 110 Puma 2.2 SW Indus Silver
Hello! Long time reader first time poster!
2014 Defender 110 2.2 tdci
I am having my first bash on repairing the defender. I did have a noisy viscus fan bearing however time run out and it finally failed.
Failure:
I have started the removal process my first question i think i have the answer but wanted to check in case there is a tool or a method but does the alternator need to be removed?
There seems to be a bolt above the number 9.
Looking online there looks to be a treaded mount.
Also i am looking at either ordering from maltings 4x4 they seem to be best priced with good reviews and feedback.
Any other companies that are recommended please let me know.
Thank you!
Post #987011 27th Mar 2023 1:03pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Yes, the bolt above number 9 needs to be removed to release the accessory drive component bracket.
For that, you first need to remove the 3 bolts holding the alternator to the alloy bracket on the left of the engine. You should not need to completly remove the alternator from the engine bay though, just reposition it a bit forward or to the side so you can access the bolt above number 9. Best would be to disconnect the battery before so you don't short anything while manipulating the alternator as it has permanent live connection to the battery.
/Mat
Post #987059 27th Mar 2023 7:42pm
John P
United Kingdom 2012 Defender 90 Puma 2.2 SW Corris Grey
Post #987060 27th Mar 2023 8:06pm
humby
Thanks very much!
3hrs later and yes the bolt does need to come out! I did remove the 3 alternator bolts and moved the alternator out of the way to remove the bolt and release the bracket.
My alternator bolts to say they where seized is an understatement, we really struggled with the restricted access to remove the 3 alternator bolts.
I am actually going to get some replacement bolts for the alternator.
I ended up using https://maltings4x4store.co.uk and ordered a new belt, belt tensioner and bracket and bearing.
Ill make sure to disconnect the negative terminal when i come to re install everything must admit i should have but did not for the bracket removal.[/url]
Post #987063 27th Mar 2023 8:17pm
The 2.4 has the matching bolt on the nearside as well (deleted or possibly just omitted on the 2.2) and it is staggeringly awkward to remove. It makes the one behind the alternator seem easy.
Post #987085 28th Mar 2023 6:38am
humby
We had so much quarry dust built up on the alternator bolts they where so tough to undo, most of our time and effort was spent on removing the 3 bolts on the alternator.
I managed to order some FB110226 from https://www.lrparts.net/
I was reading the Haynes manual looks like they will need to be torqued to 48 Nm.
Am i missing an easy access panel for the alternator bolts we are accessing them from underneath with a spanner then a socket once we have the clearance between the frame and bolt gap.
I do also have the filter box removed and the turbo intake pipe out of the way for better clearance.
Maybe "This is the way" Laughing
Post #987095 28th Mar 2023 10:22am
John P
Yes "this is the way" I did it, from the top. Airbox and boost hose out of the way. Still not easy.
Post #987098 28th Mar 2023 10:38am
humby wrote:
... I was reading the Haynes manual looks like they will need to be torqued to 48 Nm. ...
I would respectfully suggest that the alternator bolts are yet another example of the sort of fastener where there is absolutely no point whatsoever in using a torque wrench, just do them up sensibly.
Post #987129 28th Mar 2023 4:35pm
humby
Thats good to know! We was deliberating if loctite as needed in case they could be susceptible to vibrate out loose.
Sensible tight works for me given the location and access!
Post #987150 28th Mar 2023 5:49pm
humby
I did complete the repair withe the help of the brother in law and he kindly built me a viscous fan tool!
Key take away points!
- The hidden bolt that requires the alternator to be moved back.
- The 3 bolts to remove the alternator man what an effort! Need to get some spanners!
I ordered all my bits from https://maltings4x4store.co.uk
BRACKET AND BEARING - Bearings - landrover
PULLEY - TENSION - Pulleys - landrover
V-BELT - Cambelts and Aux Belts - DE
Post #991847 8th May 2023 2:29pm
