Home > Puma (Tdci) > Rad cold after coolant flush |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3414 |
Sounds like engine not yet reached full operating temperature, so thermostat still closed. Especially if you were using the heater to warm the cabin, with low external temperatures, and not too much load on the engine. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
23rd Mar 2023 6:57pm |
Ad-doublecab Member Since: 05 Jan 2021 Location: London Posts: 64 |
Thanks for replying I’ll take it for a longer drive with heaters off!
23rd Mar 2023 7:19pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20314 |
You want more like a 20 mile round trip and with the heaters off, depends on ambient temperature but it can take a while to get up to temperature.
Usually a couple of miles starts warming up, about 4 miles should be up to temperature but to fully heat up to maximum more than that. Did you follow the bleed process of the workshop manual? ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
23rd Mar 2023 7:40pm |
Thanks Steve, I’ll take it for a longer drive only thing I didn’t do was disconnect the oil thermostat coolant hose 😬
23rd Mar 2023 8:13pm |
Update So I took it for a longer drive today 50 miles in total with the heater off the car was cutting in and out of power then died temp was half way, heater on alway is very hot and but drives okay rad was cold when I got back engine running but when switched it off rad was hot on the top right hand corner 😕 Anyone has this issue before? Cheers |
28th Mar 2023 3:17pm |
pdv Member Since: 07 Feb 2014 Location: Asse Posts: 26 |
any news ? i have exactly the same problem.
thanks |
19th Jun 2024 9:50am |
I put a new rad, new stat and was still the same then changed the heater control valve and that fixed it check your valve before replacing anything else
19th Jun 2024 10:23am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
Did you fit one of those low temp thermostat? Puma 110" SW
19th Jun 2024 11:55am |
Started off with a normal one second one I fitted was the low temp stat
19th Jun 2024 12:08pm |
I am switching back to the original one asap. And I´ll keep the oil cooler thermsotat off though. Puma 110" SW
19th Jun 2024 12:13pm |
hi all
my new OEM thermostat was totally faulty ( not opening) and the old one didnt open all the way, so after 2 new thermostats everything is back to normal. original 86° stat fitted now that solved everything. cheers T. |
26th Jun 2024 6:17pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
Thank you very much for your feedback!
27th Jun 2024 7:52am |
