Home > Puma (Tdci) > Replacement Steering Damper
MattyEssex
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Indus Silver
After some advise, changing my rusty steering damper out and the replacement Old Man Emu is just to big to go into the fixing.
I’ve removed the surface rust that had built
up but is still too tight to get it in.
Other than heat up and try to widen slightly, not sure how I’ll do that, can anyone else suggest how to get it in?
Also can you drive without one on?
Post #986225 20th Mar 2023 7:15pm
bear100
Very Happy A pricey fix but a much better end result is to fit the Gwyn Lewis Sumo bar kit
Had the same issue and fitted the kit on the drive, great upgrade 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #986227 20th Mar 2023 7:37pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I had exactly the same problem with what looks like it may be the same yellow-painted make of damper. The metal insert of the bush was a millimetre or two too large. Turned out there was nothing wrong with the old one after all, but my plan had been to carefully grind down the insert. Wasn't confident in my skills to get a good finish, mind.
Post #986232 20th Mar 2023 7:56pm
landy andy
Yes you can drive without one, and you shouldn’t notice a massive difference if the rest of the steering system is ok, and especially if your old one is knackered.
I’m in Herts near Essex and if you want pop over and I will grind a few mm off the centre bush.
Post #986236 20th Mar 2023 8:15pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Had the same with OME steering damper. Just grind the metal insert and it will slot in the bracket. Should be a snug fit anyway as when tightening the bolt it should lock both faces of the bracket against the metal insert.
/Mat
Post #986238 20th Mar 2023 8:16pm
MattyEssex
Andy thanks so much I have managed to get it so close but just cannot get the final mm’s
Post #986241 20th Mar 2023 8:29pm
landy andy
That’ll go. Get a podger in there. Wink
Post #986248 20th Mar 2023 8:44pm
hornet
Post #986308 21st Mar 2023 12:46pm
MattyEssex
Just wanted to say thanks to Andy for helping me out today, top guy and had it all fixed up in 15mins !!
Post #986329 21st Mar 2023 3:40pm
landy andy
No problem. Pleased to help, and nice to meet 👍🏻👍🏻
Post #986347 21st Mar 2023 6:06pm
