Home > Puma (Tdci) > Replacement Steering Damper |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1916 |
A pricey fix but a much better end result is to fit the Gwyn Lewis Sumo bar kit
Had the same issue and fitted the kit on the drive, great upgrade 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
20th Mar 2023 7:37pm |
swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 163 |
I had exactly the same problem with what looks like it may be the same yellow-painted make of damper. The metal insert of the bush was a millimetre or two too large. Turned out there was nothing wrong with the old one after all, but my plan had been to carefully grind down the insert. Wasn't confident in my skills to get a good finish, mind.
20th Mar 2023 7:56pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Yes you can drive without one, and you shouldn’t notice a massive difference if the rest of the steering system is ok, and especially if your old one is knackered.
I’m in Herts near Essex and if you want pop over and I will grind a few mm off the centre bush. |
20th Mar 2023 8:15pm |
MatLandy Member Since: 11 Sep 2020 Location: Paris Posts: 184 |
Had the same with OME steering damper. Just grind the metal insert and it will slot in the bracket. Should be a snug fit anyway as when tightening the bolt it should lock both faces of the bracket against the metal insert.
/Mat |
20th Mar 2023 8:16pm |
MattyEssex Member Since: 23 Jul 2021 Location: Essex Posts: 77 |
Andy thanks so much I have managed to get it so close but just cannot get the final mm’s Click image to enlarge |
20th Mar 2023 8:29pm |
That’ll go. Get a podger in there.
20th Mar 2023 8:44pm |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 361 |
21st Mar 2023 12:46pm |
Just wanted to say thanks to Andy for helping me out today, top guy and had it all fixed up in 15mins !!
21st Mar 2023 3:40pm |
No problem. Pleased to help, and nice to meet 👍🏻👍🏻
21st Mar 2023 6:06pm |
