Home > Technical > Filler Necks |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1051 |
Pictures of filler neck of a 1999 Td5 CSW
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
16th Mar 2023 9:34am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 809 |
I went the opposite way and during a chassis replacement fitted the later (Td5 onwards) plastic tank with the smaller neck. I had to cut a support plate to reduce the diameter of the tub opening to match the rubber neck support ring.
I guess in your case you just need to cut out the opening hole of the new tub to match the old tub? |
16th Mar 2023 9:42am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6092 |
When I built my 110 (Td5) but with an earlier rear tub.
I used the older filler unit (so I could keep the jerrycan pull out tube...dead handy!) and made the pipework fit the Td5 tank. Can't remember what I did now though. |
19th Mar 2023 2:24pm |
Pacha Member Since: 23 Feb 2020 Location: North Yorkshire Posts: 772 |
There seems to be quite a few variations across the years - even on the same vehicle?. Rgds.
Chris Last edited by Pacha on 23rd Mar 2023 7:51pm. Edited 1 time in total |
20th Mar 2023 7:01pm |
Oldvog Member Since: 28 Jan 2023 Location: Essex Posts: 9 |
Thanks everyone I think going to open the hole up to take my current fitting as I think they work better than the plastic ones
23rd Mar 2023 7:51pm |
