Home > Technical > Replacing battery silently
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
The BBUS is triggered when the battery is disconnected. I know this because the current battery is on its way out and the BBUS has been triggering on start up due to voltage drop.
So, how to replace the battery silently? Or is just a case of using ear defenders? Fortunately we're out in the sticks so there's not any neighbours to annoy.
Post #985564 14th Mar 2023 8:09pm
Ashbyandy
England 2015 Defender 110 Puma 2.2 Adventure Phoenix Orange
The process,
1. Loosen the battery terminal clamps ready to pull off
2. Turn the ignition on for 10 secs, but don’t start the vehicle
3. Turn off, and remove the negative battery terminal within 15 secs, ( hence why you loosen them first)
The alarm shouldn’t sound, if you do this correctly. But don’t take too long to remove the terminal, or it will re-arm,
Good luck,
Andy 👍
Post #985566 14th Mar 2023 8:17pm
steveww
Thanks for the tip.
Post #985600 15th Mar 2023 9:51am
Sjmmarsh
United Kingdom 2009 Defender 90 Puma 2.2 XS CSW Santorini Black
Only loosen the NEGATIVE terminal. If you do the positive one as well, you may find that your spanner is welded to any bit of the chassis it comes into contact with. It also gets very hot very quickly!
Steve
Post #985658 15th Mar 2023 6:03pm
As above and remember to remove the negative first, then the live.
Then when fitting the new battery, live first then negative last.
A racket to spanner that has an insulated end and handle is best where possible, because as mentioned anything metal if you accidentally contact the live to any other metal item it’ll weld itself to it in seconds.
Plus sparks are not ideal in the area.
Don’t forget to connect the breather tube and check it’s clear.
Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #985685 15th Mar 2023 9:38pm
