Home > Technical > Replacing battery silently |
Ashbyandy Member Since: 17 Dec 2015 Location: Leicestershire Posts: 223 |
The process,
1. Loosen the battery terminal clamps ready to pull off 2. Turn the ignition on for 10 secs, but don’t start the vehicle 3. Turn off, and remove the negative battery terminal within 15 secs, ( hence why you loosen them first) The alarm shouldn’t sound, if you do this correctly. But don’t take too long to remove the terminal, or it will re-arm, Good luck, Andy 👍 |
14th Mar 2023 8:17pm |
steveww Member Since: 05 Jan 2022 Location: Uppingham Posts: 571 |
Thanks for the tip.
15th Mar 2023 9:51am |
Sjmmarsh Member Since: 01 Jan 2023 Location: Lincs Posts: 59 |
Only loosen the NEGATIVE terminal. If you do the positive one as well, you may find that your spanner is welded to any bit of the chassis it comes into contact with. It also gets very hot very quickly! Steve |
15th Mar 2023 6:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20472 |
As above and remember to remove the negative first, then the live.
Then when fitting the new battery, live first then negative last. A racket to spanner that has an insulated end and handle is best where possible, because as mentioned anything metal if you accidentally contact the live to any other metal item it’ll weld itself to it in seconds. Plus sparks are not ideal in the area. Don’t forget to connect the breather tube and check it’s clear. No Guts, No Glory. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
15th Mar 2023 9:38pm |
