Home > Td5 > 2nd row seat floor sheet metal/alu.
doruk1981
Switzerland 2002 Defender 110 Td5 SW Coniston Green
While endulging myself yesterday with the 2nd row seat floor, I realized the aluminum behind de seat mount has corroded away. Therefore had to be added to the to-do list (which at the moment is not getting shorter)...
lrworkshop points to part 8 as a replacement, which unfortunately costs a pretty penny...
I naturally started looking for alternatives and noted that YRM is also offering some interesting solutions - but given their product IDs are different, its not easy to know which would fit the best.
the full kit is:
https://yrmit.co.uk/product/rear-body-floo...er-110-sw/
but given that my trunk floor is mostly decent, I was wondering if I truely need to replace everything and if I could not just get the front part where the seats are mounted?
I noted they have this one:
https://yrmit.co.uk/product/2nd-row-footwe...or-5-door/
I'm just not sure if its the right one for the station wagon setup. Also based on the pictures I see that there are no holes predrilled?
Would much appreciate your insights how to fixed this alu-misshap
thanks
Doruk Td5 110 Station
Post #984949 9th Mar 2023 4:16pm
rallysteve
If you look on the YRM workshop section of the site there is a step by step of replacing the crossmember below that part and that section of floor you posted.
Is it the vertical section which has corroded or the top section?
You would drill all of the holes to suit your vehicle.
Post #984950 9th Mar 2023 4:30pm
BrickBox
There is also this one from GDi
https://www.ebay.co.uk/itm/294850821115?mk...media=COPY 2008 2.4 110 Utility Station Wagon XS.
Post #984951 9th Mar 2023 4:33pm
doruk1981
yes its the vertical section where the seat mounts live. After taking off the three screws the alu came along. The plus side is that i can see the crossmember (which also needs to be replaced) rather nicely now Td5 110 Station
Post #984992 10th Mar 2023 8:31am
rallysteve
If it is just the vertical face then I would just swap this part over:
https://yrmit.co.uk/product/2nd-row-footwe...eries-lwb/
Bear in mind that it would be an ideal time to also replace the mid-body x-member behind (if it hasnt already been replaced) as they are usually in poor condition and without this panel in place fitment is dead easy:
https://yrmit.co.uk/product/110-mid-crossm...-defender/
Post #984998 10th Mar 2023 9:25am
doruk1981
Thanks for the pointer, the reason why I ended up with this problem, was actually the mid cross member, as I need to replace it.
to get the floor pannel out easier, I started screwing off the mounts and then the dead aluminium showed itself.
The C post sections are already laying around in the workshop and will be replaced as well
 Td5 110 Station
Post #985000 10th Mar 2023 9:33am
rallysteve
Thumbs Up
Have been in exactly that situation myself previously. I ended up just temporarily patching the damaged areas at the time but replacing that section is a much better solution.
Cheers,
Post #985004 10th Mar 2023 9:53am
rustandoil
My Doublecab was in a very similar state, the job escalated for me to a sort of "restoration / refurb /upgrade ..... I currently have the front axle out! 😂 😂
Post #985013 10th Mar 2023 11:53am
TexasRover
You often find that when you need to change your rear seat mounts, the front axle will need changing also.
Post #985057 10th Mar 2023 5:34pm
