Home > Puma (Tdci) > Crossmember Bolts. |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3431 |
Assuming it is for a 2008, then it is simply unscrewing them. Nut is welded to the retaining bar. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
7th Mar 2023 8:25am |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 840 |
Fantastic!
Thank you. 2008 2.4 110 Utility Station Wagon XS. |
7th Mar 2023 8:29am |
When I did mine, I used stainless and added a nylon washer and a dab of Duralac to separate the different metals:
Click image to enlarge More details here: https://www.defender2.net/forum/post829011.html#829011 Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
7th Mar 2023 8:37am |
Similar to what LRA has done, though I used cheap chinese screws (what is not made in China anyhow).
They look a bit more stock, less the rust. https://www.aliexpress.com/item/4000370174...lyTu8c5HQE 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
7th Mar 2023 11:33am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
How good is the quality of these screws? Do they attract a magnet? There is some rubbish ss screws doing the rounds and if thy attract a magnet you know they are full of rubbish steel.
8th Mar 2023 12:00am |
Care not to put all stainless steels in one basket. There are lot of grade of stainless steels, and 400 series stainless steels are actually magnetic (although not generally used for fasteners).
I expect the bolts that I linked to, to be grade A2, and strength wise I have no doubt that they are fit for purpose. Just to note that the rear tub rail uses 10 bolts tub to rail, while half as much bolts (if memory serves me well) for rail to crossmember. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
8th Mar 2023 4:35am |
a2 /304 ss (most commonly used in motor trade)as i understand it should not be strongly magnetic (under some circumstances 304 might be a little if annealed in processing )
a4/316 used in marine industry should not be magnetic. .........so if i was buying any of those on flea bay i personally would not be happy to use if they were magnetic. https://www.eclipsemagnetics.com/resources...-magnetic/ |
8th Mar 2023 1:04pm |
For critical applications, you would still not want to use stainless steel bolts, whereever and by whoever they are made.
For the rest, I would not mind as long as there is no bigger risk of introducing galvanic corrosion (the risk is always there whatever you use). In most, if not all of the body fasteners on a Defender, the fastener is much stronger than the metal around the fastener. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
9th Mar 2023 6:12am |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 386 |
I just replace using OEM bolts from JLR. Quite cheap and then keep a bit of Acf50 on them. My 90 is 8 years old and have replaced only recently due to very slight corrosion. I like the look of clean bolts. OCD 2015 90 XS Santorini Black
9th Mar 2023 6:35am |
