![]() | Home > Technical > Headlamp Alignment Switch -Illumination |
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
Hi. Yes mine had a green led soldered onto the board. Very dim. I ordered led bulbs from ebay I think, and soldered a pair onto the board. Lights up a treat now.
Prior to that, I had issues with the switch not working. Stripped it and soldered all the joints again and has worked perfectly since. 2009 Defender 90 CSW 2.4 TDCI. Ex Army Mechanic still living the dream. |
As above
Albarker55 Member Since: 02 May 2022 Location: Fleet, Hants Posts: 22 ![]() ![]() |
Thanks both for your replies. Guess it’s the dash out again and some switch disassembly and repair effort. Any clue on the LED bulb and where on eBay I can get one.
Of course, here you go https://www.rapidonline.com/barthelme-2110...en-57-6825
I chose the green LEDs to keep with the Defender lighting theme. FYI it is the same bulb in the headlamp levelling switch as well. ![]() |
Thanks for the link. All ordered. Will attack the switch refurb over the next couple of days
You're welcome and good luck
From memory, there is a fiddly little spring inside the body? Use a hair drier to warm the outer case so it flexes to pop it apart! 2009 Defender 90 CSW 2.4 TDCI.
