Home > Td5 > Wiring looms?
jim4244
England 2007 Defender 90 Puma 2.4 CSW Zermatt Silver
Wiring looms?
Hi all
I a basic, bog standard TD5 90 are all the wiring looms in place for things like rear windscreen wiper and electric windows or, if you want to install them, do you have to run your own cables?
Jim
Post #982700 16th Feb 2023 9:33pm
Retroanaconda
Electric windows were only an option from 2002 onwards so definitely a no for those if it’s before then. If after then potentially but unlikely as the main loom has to have it built in at manufacture.
Rear wiper would depend on the original specification. A hard top or station wagon would have the wiring, a truck cab or rag top potentially not depending on which box they took the loom out of in the factory that day.
Post #982706 16th Feb 2023 9:48pm
TexasRover
On my 2002 110 DCPU behind the centre console there are surprisingly many unused plugs. I ID'd them all at some point and yes they are rear screen heaters etc connectors which would only be applicable to a station wagon. Probably the easiest way to start.
I find there can also be plugs hanging loose where a section is missing. I have a rear speaker plug hanging in the engine room bay, where clearly the parts that goes to the back is not installed.
Central locking and electric windows are separate looms that extend into the doors. I have neither and definitely no wiring going into my doors. You can buy those looms for reasonable prices as aftermarket parts like on LRPARTS etc.
Post #982712 16th Feb 2023 10:37pm
andy2111
United Kingdom 2002 Defender 110 Td5 HT Bonatti Grey
Worth checking out autosparks for looms too... TD5 hardtop to Puma inspired Poptop - my build thread
2002 110 TD5 Hardtop ¦ Full Puma interior ¦ Carpathian grey / Santorini black ¦ X-Vision-X poptop
Post #982726 16th Feb 2023 11:53pm
jim4244
I’m looking at a 54 plate TD5 hardtop, but it is very basic with only a heated rear screen. If the wiring is in place to fit a rear wiper etc it’s something I would definitely consider doing.
Jim
Post #982776 17th Feb 2023 1:27pm
Martin
Site Admin
I think on the Td5s the rear wiper wiring was in all the looms, unlike the earlier ones where it was an overlay loom from the factory.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #982777 17th Feb 2023 1:34pm
rallysteve
My bog standard 2002 DCPU (facelifted dash) had the looms for the heated rear window and rear wash/wipe installed to the rear. Front wing looms had connectors for the rear washer motor, BBUS and headlight levelling. The bulkhead loom did not have the wiring for rear speakers. Wiring for the passive immobilizer coil was installed but the passive coil was not. I vaguely recall the left hand speaker was a dummy one too but I might be remembering that wrongly.
Roof loom had only the wiring for the front interior light, no wiring for alarm volumetric sensor.
None of the wiring, connectors or relay for heated seats, heated windscreen, electric windows or central locking were fitted as these were all spec dependent.
Post #982781 17th Feb 2023 2:34pm
