Home > P400e Area (L663) > Camping / Sleeping in P400e? |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2765 |
Best car I’ve ever slept in!
The slightly raised boot floor isn’t a big problem, I just got 2 ‘pieces’ of mattress foam, one thicker than the other - the thicker bit goes over the folded second row seats and the thinner bit in the boot. Sliding the front seats forwards gives you a full 190cm length and I cut a notch into the foam which locates nicely on the upright part of the middle row seats when folded. The P400e is ace because you can use the heater and stuff without running your engine 👍 Click image to enlarge Click image to enlarge Click image to enlarge Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
13th Feb 2023 8:41pm |
G&T Member Since: 13 Jul 2021 Location: Shropshire Posts: 38 |
That’s my preferred option David. You should have seen the looks in the dealership as I tried the length of the boot space with me stretched out. It certainly made the RR suits look a tad confused.
13th Feb 2023 11:08pm |
JARowley Member Since: 28 Dec 2022 Location: Nottingham Posts: 88 |
Is this a custom-built matress? |
14th Feb 2023 11:15am |
Nope just bought generic foam mattress pieces (2 pieces which combine to give 130x190cm from memory) and trimmed to shape - wasn’t too hard at all. I’ve then got a fitted sheet which works quite nicely tucked underneath. Cheers, David
14th Feb 2023 1:23pm |
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1431 |
14th Feb 2023 9:51pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1186 |
come MOT time, will you need an Habitational Check
15th Feb 2023 8:32am |
Elbek Member Since: 14 Dec 2024 Location: Uzbekistan Posts: 9 |
14th Dec 2024 8:01am |
Hi! I was looking everywhere and could not find out. Im planning to go camping in my Defender p400e. I was wondering, will the fridge connected to the socket in the trunk drain my 12v battery? Do I need to install another battery? Or I can just drive to a camp site with safe mode and everything will use big battery to run all the sockets? |
14th Dec 2024 8:02am |
