Home > Maintenance & Modifications > Superpro bushes DIY?
bear100
Hi all
I have purchased a Superpro bush kit for my puma
Are all the bushes a diy fit using standard tools on the driveway? Ie no hydraulic press etc.
I do have a vice though! 2016 Range Rover Autobiography 4.4 TDV8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #982299 13th Feb 2023 3:40pm
The difficult part is usually getting the old bushes out. Darren
Post #982302 13th Feb 2023 3:55pm
steveww
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Bronze Green
Pushing the new ones will work with a vice. Getting out the old ones is a totally different kettle of fish.
To remove the old ones without a very big press requires a bit of work but is possible. What I've found that works is:
Use a whole saw to remove the rubber innards.
This leaves the old metal sleeve.
Use a hacksaw the cut through the sleeve, careful not to damage the suspension part.
A large hammer and drift/chisel or air hammer to bash the sleeve out.
You want to curl it in on itself a bit from both sides first.
You'll also need an air wrench (dugga, dugga) or a long breaker bar and a big torque wrench. Some of the nuts and bolts are quite large so make sure you've got sockets and spanners big enough before you start.
Post #982303 13th Feb 2023 3:58pm
geobloke
Re: Superpro bushes DIY?
bear100 wrote:
Hi all
"Super" bushes Thumbs Up The last set I did without a vice and it worked beautifully... In and out. Job done. https://www.defender2.net/forum/topic53859-225.html
Post #982306 13th Feb 2023 4:22pm
Litch
Fitting SuperPro bushes is easy enough with a vice.
Removing OE bushes without a press is easy enough, I have always gone with the hole-cutter / hacksaw blade method.
This is my A-frame, less than 10-mins per bush.
 ONE LIFE, GET IT!
Post #982310 13th Feb 2023 4:27pm
hank
Definitely a DIY job, but a whole kit is time consuming. I paid someone to fit mine as I couldn't be arsed spending a whole weekend fitting bushes > 110 XS Double Cab
Post #982312 13th Feb 2023 4:37pm
donmacn
This is what I've done. Just a small thing to add, which you'd think would be obvious (but it took me a while... Whistle ) ... spray some WD40 onto your hole saw periodically otherwise the rubber melts, binds to the saw, and makes your drill work really, really hard. A wee bit of lube and it goes through the old bush so much fastet. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #982315 13th Feb 2023 5:07pm
edward
I’m about to get the garage to do mine - at the same time as I do a full suspension upgrade- how long do you think it should take? So I don’t get taken for a ride … thanks
Post #982325 13th Feb 2023 6:29pm
bear100
Great news! Thanks for the replies and lots of tips
Well saying great news what I really mean is…….more skinless knuckles, cuts, Dinitroled hands and arms, a full on shift with lots of cursing and sweat! And all the while thinking why did I start this! Lol
Had a nightmare removing the drop arm to fit the Gwyn Lewis kit Sunday so might put it off for a bit! 2016 Range Rover Autobiography 4.4 TDV8
Post #982351 13th Feb 2023 8:31pm
landy andy
Just swapped all my bushes from LR ones to Supepro ones. Just used vice, hacksaw, chisel and hammer. Gwyn Lewis does a good price for the full bush kit, and also does a bolt kit, so you can have new bolts for all the new bushes if required.
Post #982363 13th Feb 2023 9:32pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
How does it feel since the change?
Post #982377 13th Feb 2023 10:20pm
landy andy
Much tighter, firmer, but less crashy. Although I did also do full suspension swap at same time, and steering bars. So it has all made a massive difference to me. Only thing I didn’t do is rear axle ball joint, and it’s bushes which is on the list once I purchase the forgotten ball joint.
Post #982380 13th Feb 2023 10:36pm
donmacn
I think I wrote this up a little as part of my resto thread, but when I fitted these bushes all round it made a big, noticeable difference to the car. Much more precise steering, and no downsides that I could see.
Bear - I feel your pain! I had a similar ‘mare doing mine. Ended up grinding through it. If you’ve done the sumo bars mod, and are now doing the bushes I think you’ll be really pleased with the results. Donald
in the past..
Post #982398 14th Feb 2023 9:03am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Bushes
Have done this on a number of vehicles with/without a press.
If you are in a position where you have a friendly garage with a press close by- its probably worth taking all the various bits to them and getting them to press them out- it can be a faff getting the bushes out otherwise and quite time consuming- but perfectly doable if you don't mind spending time persevering with a hacksaw and a cold-chisel.
A decent round edge file and some emery cloth to tidy any poor edges on the components is well worth it.
While you are about it, its worth spending the extra bit to renew the various bolts/fixings too- the bolts in the upper A-Frame in particular are often necked.
Chris
Post #982453 14th Feb 2023 5:51pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
I'm not sure if it's recommended but I always burn out the old bushes with a blow lamp, them hacksaw out the metal part, finishing with a cold chisel. They can fly out though, so best done in the open, not by your head and it stinks. I never thought of a hole saw, I might try that next time.
Post #982495 14th Feb 2023 10:10pm
