Home > Maintenance & Modifications > Intermittent electric window fault |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1210 |
Hi
I had the same and then it stopped all together. I did the following - Remove the door trim and vapour barrier Unplug the wire connection to the motor (fiddly but possible Pull the rubber ducting out of the door post Carefully pull out the wires until you see both connectors, one is for the central locking the other the window. Check the continuity on both wires. On mine the red wire had failed somewhere in the middle of the runner ducting so I pulled a replacement wire to bypass the original. Job done. Fiddly but hope this helps. 2010 XS USW 1957 Series One 88 diesel 1958 Series One 88 4x2 |
12th Feb 2023 6:07pm |
Sk1ppy Member Since: 19 Dec 2022 Location: Newbury Posts: 17 |
Thanks
12th Feb 2023 6:12pm |
HTB Member Since: 24 Mar 2013 Location: Surrey Posts: 71 |
It a feature.
I think it’s normally the central locking that goes first due to the flexing of the cable, and normally on the drivers side as that’s the door that gets used most…. So, whilst you’re in there, double double check for cracked insulation on all of the wiring. |
12th Feb 2023 6:47pm |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2080 |
That’s exactly where mine failed many years back. Soldered the break and covered in heat shrink. Been fine ever since |
12th Feb 2023 7:21pm |
still not sure where the break was (other than somewhere in the middle) but as I had some wire to hand I did not bother to look.
I also added some sound deadening to the door skin and gave the bottom of the door a good spray of ACF-50 as well. I only broke one clip in getting the door card off. Just waiting for some tiger seal to re seal the vapour barrier before I can pop the card on. I am using it without at the moment, an even more basic look 2010 XS USW 1957 Series One 88 diesel 1958 Series One 88 4x2 |
12th Feb 2023 8:09pm |
