Home > Technical > Heater blower, radio, cigerette lighter not working
Arkangle
United Kingdom 2009 Defender 110 Puma 2.4 HT Zambezi Silver
Off on holiday next week and sure enough something pops up with my trusty steed. First indication was that the radio would stop then start again but now if i switch the heater on or plug sat nav in cigerette lighter they all go off. After a while i can get the radio to come back on but it is the only thing that will work independantly switch blower or use cig ligher independantly they dont work or if radio is on that shuts down too. There power going to fuses, non blown. I have ordered new ignition switch as i know they are all on aux position but will this be the problem as power igoing to fuses or is there something else i can try before.
Post #982163 12th Feb 2023 11:26am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
If it's just these three and the fuses 26, 27 and 28 are fine (and also firmly inserted) then it's probably the ignition switch I'd say. There's no relay or aux-only main fuse involved here.
note: probably the wrong forum section for this question
Post #982181 12th Feb 2023 5:05pm
Arkangle
Thanks, have similar view but you never know. Point noted re. Correct aection to post, new to site
Post #982209 12th Feb 2023 8:11pm
HardCharger
Probably time for a new ignition switch
Post #982242 13th Feb 2023 1:16am
