![]() | Home > Technical > ECU - Engine computer thingy? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
It's right at the top of the bulkhead behind the engine, it's a long way up but *might* get wet if water crashes over the bonnet.
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
The water would have to be pretty deep,, but still, their must have been a better place to put it !!
![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Main Brian James Trailer Dealer for South West UK |
solmanic Member Since: 16 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
It is higher than the old one under the driver's seat. And if you're doing a water crossing correctly then the water level inside the engine bay should be a damn sight lower than that outside. 2007 Defender 110
1970 Alfa Romeo 1750GTV |
TBH theres a
![]() I think its a in a better location compared to under the drivers seat. |
Milligan Member Since: 07 Dec 2007 Location: Somerset Posts: 32 ![]() ![]() ![]() |
I thought that it may have been the case... he was drooling at the time.
I�m not sure if he thought I was taking the ![]() ![]() Thanks for the feedback, feel reassured that I'll have bust everything else and the ECU will still work! What we're really saying is that before this is an issue the whole thing needs careful attention for deep water. ![]() |
Or consider a boat ![]() |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
You have no worrys regarding the ecu, it is a sealed unit and the connectors also have seals in them.
If its run under watter it wont get inside the ecu. Regards Pete |
