Home > My Defender > BeaTie |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5226 |
changed the fuel relay and we seem to be a little better, but still down on power, so i am changing the fuel filter out tomorrow, i am starting to wonder if the diesel i have in the tank has been contaminated with water, due to all that rain. because the tank was brimmed, now its starting to use it and the car seems to be getting a little better. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
20th Jan 2023 6:30pm |
well this problems had a right old laugh at me! The fuel pumps bit the dust there, the car died on me and my dad while we were doing the brakes, and it wont start at all.
We checked the new fuel filter, and there was no diesel in it. My dad couldn't hear anything at all from the rear at all, But it was hard to hear due to the bloody asda traffic. So this is going to be a laugh to do! Its already had a replacement one in, not long before i bought her. Looks like its had a cheap one installed and its gave up! The common rail trouble bites my arSE again!! The 306 was out of action last year due to a fuel pump and now this You got to laugh eh Just forked out on a nice upgrade too Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
21st Jan 2023 8:19pm |
what wheels do we have in the box? any guesses
Click image to enlarge Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
2nd Feb 2023 8:58pm |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2179 |
Round ones per chance........
2nd Feb 2023 9:04pm |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 |
But they’re square boxes?!
2nd Feb 2023 10:36pm |
maybe Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
3rd Feb 2023 5:45am |
DSC-off Member Since: 16 Oct 2014 Location: North East Posts: 1440 |
Peugeot ones???
3rd Feb 2023 1:55pm |
wont fit Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
3rd Feb 2023 4:04pm |
update, the tank is out and fuel pump has been swopped over, but the fuel neck rubber ring dropped to pieces and destroyed the fuel cap
We had a barney getting the white ring on from the kit, and the black locking ring put up a fight too, we thought we had that locked, but it popped straight off. So tomorrow we crack at again, got replacement bits ordered off, new rear guard and fuel cap, and the breather hose has seen better days. I hope this runs like clock work after all this Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
5th Feb 2023 2:42am |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 |
Hi procta i hope with all of this it will sort the issue out once and for all🤞 Could they be wolf wheels cheers Paul
5th Feb 2023 11:25am |
I hope so too, this is been off the road for a couple of months! it needs an MOT and its new wheels on, Nope not wolf steelies Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
8th Feb 2023 9:02pm |
back in action!!!
Fuel pump was the main problem after all this faffing about, Looks like when these die, the car still runs. Where the Peugeot would just shut off if it doesn't see a certain PSI of fuel. Not really that much of a pain to do really, if the tanks empty and there are two of you, All about feeding the pipes back through which helps. Did the priming sequence, and a few turns with the key and it fired over, and idled, i had an Allmakes crank senor in, and as soon as i tapped the pedal, the car cut right out. EM light straight on, I said right ok. Original one back in and fired up again, and its running better than the day i bought it! So those cheap senor's don't do all really, cause more issues. Changed the following units, New pedal, ( suspecting that to have been putting the light on the odd time) cleaned the ECU from oil and a new injector loom, Replaced the fuel pump relay for the sake of it Then changed the fuel pump, with a decent quality unit and an opitmil fuel cap Changed the crank sensor loom for a bypass unit. YRM tank guard. New brake pads on again, just needs to get a MOT and i can use it again! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back Success is 90% Inspiration and 4 minutes Preparation # you can make it! |
11th Feb 2023 5:56pm |
Great news Procta have the wheels been fitted yet? cheers Paul
12th Feb 2023 8:00am |
not yet, got to get it through an MOT 1st
12th Feb 2023 2:23pm |
