![]() | Home > Td5 > CPS cable snap |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 281 ![]() ![]() |
And the solution is go to your friendly land rover parts people who have a plug that fits the CPS with tails on it so all i have to do is cut the old one off and connect the new one ... somehow ....
Simples A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb Gertie - 1999 110 TD5 - like a Phoenix from the ashes back on road... almost Effie - 2004 110 TD5 County |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
Plug is a basic 2pin Econoseal type (https://www.ebay.co.uk/itm/143412803593)
Just cut the old one off and crimp on new terminals onto a fresher section of the existing cable. Steve 02' 110 TD5 Double Cab Rebuild Thread |
ok thanks for the link much appreciated
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1167 ![]() ![]() ![]() |
For these events, I chop the connectors of the 'replaced injector harness', which are of this same type. Have a few in a toolbox in the car. They are pretty good for a quick fix, but the insulation tends to have hardened from sitting inside the engine.
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6644 ![]() ![]() ![]() |
Definitely a different connector to the injector
![]() Click image to enlarge You are correct different connector. I got confused with the various temperature sensors. Quickly nipped into the garage where i have a 1999 R380 lying around and took a quick picture for reference. The roundish one is the CPS |
