![]() | Home > Maintenance & Modifications > Occasional Battery Drain |
drewster Member Since: 13 Jun 2011 Location: south coast brockenhurst Posts: 226 ![]() ![]() ![]() |
you are right you could have a sticky relay do you have heated seats ?
rear screen?or front screen? |
or sticky relay on glow plugs?
Brendan |
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
There's a heated rear screen. Could this be it ?
If the glow plug relay was sticking should the pilot light illuminate on the dash ? |
Assuming you have electric windows check the contacts and cables and switches. Also check your main earth strap and overall have a good look at the battery and its connections/cables.
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 ![]() ![]() ![]() |
Bad plate in the Battery ??? Richard
Either a 90, 110 or 130. Discovery 5 |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
It could be a sticking brake switch on the master cylinder.
Thanks for all the input so far, I'll have a try of these this evening.
Can the likes of the brake light switch flatten the battery even when the ignition is off ? |
Gets my vote ![]() ![]() |
I think I might have found the problem (not sure).
If I leave the radio on when I stop it seems to drain the battery. The radio seems to switch off when I turn off the key all right though. When I tried it by leaving the radio on the battery flattened, could this be coincidental ? It's a single disk CD player type. |
A radio draining a battery overnight?
Say 16 hours and typical 68 Amphr battery taken down to say 1/3 DOD would mean your radio is drawing about 3 amps per hour. Seems to me to be rather a arge current draw for a radio which is nominally off Possible I suppose if your battery is on the way out, but I think I would carry on looking for other reasons. Brendan |
Kinda thought as much but just wasn't sure, thanks for the pointers.
Removed the relay for the rear window heater yesterday, so I'll see how that goes for a while. |
Which relay is for the glow plugs ? Is it the small relay in the ECU compartment ? |
I removed one of the relays under the seat, which appears to be causing the drain.
The relay is AMR 3773 After doing this the following fault codes showed up: 10-6 MIL Lamp drive open load - LOGGED 10-7 Glowplug Lamp Drive Open - LOGGED. Does this mean anything to anyone ? Last edited by df1 on 14th Nov 2011 7:03pm. Edited 1 time in total |
I'm guessing that is the glow plug relay from the fault codes. Try a new relay in there and see if it solves the problem. John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
