Home > Maintenance & Modifications > Occasional Battery Drain
df1
I have a TD5 110 and it seems to randomly drain the battery overnight.
It could be alright for months at a time and then just out of the blue I come out some morning I come out and completely flat.
I tried tracing it through using a multimeter on the battery positive lead and pulling each fuse to see if there is a drain on one particular item - no luck.
It seems to just drain the battery and then if I jump it it'll be OK, just an intermittant problem.
Could a relay act up this way ? Or any other suggestions, I'm heading off on a trip in a month so would like to solve the problem before this.
Post #97686 2nd Nov 2011 2:02pm
drewster
Wales 1997 Defender 90 300 Tdi CSW Epsom Green
you are right you could have a sticky relay do you have heated seats ?
rear screen?or front screen?
Post #97694 2nd Nov 2011 2:34pm
leeds
or sticky relay on glow plugs?
Brendan
Post #97709 2nd Nov 2011 3:39pm
df1
There's a heated rear screen. Could this be it ?
If the glow plug relay was sticking should the pilot light illuminate on the dash ?
Post #97734 2nd Nov 2011 5:37pm
BigMike
Assuming you have electric windows check the contacts and cables and switches. Also check your main earth strap and overall have a good look at the battery and its connections/cables.
Post #97736 2nd Nov 2011 5:41pm
cradgebank
England 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Bad plate in the Battery ??? Richard
Either a 90, 110 or 130.
Discovery 5
Post #97762 2nd Nov 2011 7:11pm
wslr
It could be a sticking brake switch on the master cylinder.
Post #97791 2nd Nov 2011 8:39pm
df1
Thanks for all the input so far, I'll have a try of these this evening.
Can the likes of the brake light switch flatten the battery even when the ignition is off ?
Post #97912 3rd Nov 2011 3:09pm
AndrewS
Brendan
Gets my vote Thumbs Up 130's have feeling's as well you know Smile
Post #97949 3rd Nov 2011 6:29pm
df1
I think I might have found the problem (not sure).
If I leave the radio on when I stop it seems to drain the battery.
The radio seems to switch off when I turn off the key all right though.
When I tried it by leaving the radio on the battery flattened, could this be coincidental ?
It's a single disk CD player type.
Post #98398 6th Nov 2011 10:54am
leeds
A radio draining a battery overnight?
Say 16 hours and typical 68 Amphr battery taken down to say 1/3 DOD would mean your radio is drawing about 3 amps per hour.
Seems to me to be rather a arge current draw for a radio which is nominally off
Possible I suppose if your battery is on the way out, but I think I would carry on looking for other reasons.
Brendan
Post #98402 6th Nov 2011 11:09am
df1
Kinda thought as much but just wasn't sure, thanks for the pointers.
Removed the relay for the rear window heater yesterday, so I'll see how that goes for a while.
Post #98403 6th Nov 2011 11:11am
df1
Brendan
Which relay is for the glow plugs ?
Is it the small relay in the ECU compartment ?
Post #99676 13th Nov 2011 1:04pm
df1
I removed one of the relays under the seat, which appears to be causing the drain.
The relay is AMR 3773
After doing this the following fault codes showed up:
10-6 MIL Lamp drive open load - LOGGED
10-7 Glowplug Lamp Drive Open - LOGGED.
Does this mean anything to anyone ?
Post #99851 14th Nov 2011 11:21am
JSG
The relay is AMR 3778
I'm guessing that is the glow plug relay from the fault codes. Try a new relay in there and see if it solves the problem. John
2011 Tdci 110 CSW XS
Post #99865 14th Nov 2011 12:13pm
